Solved the problem.. Took the centre stand back off the bike and used a disk cutter to take off the plates that are welded onto the top of the stand pipes.
Drilled a hole in the bottom of each leg to drain any water that gets inside.
By taking off those top plates the bike stand is now brilliant. It is slightly forward of vertical and totally stable.
I know that your going to get all the road crud and moisture inside the tubes but at least it now does its job 'properly'.
