Results 1 to 2 of 2
Thread: AT plastics and glue
    futter's Avatar
    Jul 2005
    Suffolk
    When my bike went over the plastics got damaged - the holes in the tank panels were broken and I can no longer fix the rubber collared nuts/bolts together.
    I can get a strip of plastic glued to the panel to re drill the holes but I am not sure which glue to use ...
    two part epoxy stuff?
    Fibre glass it?
    Something else?
    Cheers guys.
    angelo's Avatar
    Apr 2006
    West Wales
    Re: AT plastics and glue
    I used a kit of Plastic Weld from eBay. I can absolutely recommend it BUT it is fiddly to use - you have to go with the instructions and I recommend watching the DVD that comes with it. Cost about £10 I think. Well worth it as it effectively melts the plastic back so plastic welds it.
    It comes with toxic smelling solvent and powder plastic and some pipette bottles and moulding block
  1. Glue Question
    By pete h in forum Mechanical Advice
    Last Post: 27-01-09, 07:26 PM
  2. Glue gun and panels
    By Windmill John in forum Mechanical Advice
    Last Post: 05-11-08, 10:54 PM
  3. FMX 650 Plastics
    By Jonny in forum Dominator / FMX
    Last Post: 08-07-08, 07:36 PM
  4. Removing decal glue
    By donof in forum Mechanical Advice
    Last Post: 01-12-07, 01:03 PM
  5. glue and plastic ... do they mix??
    By KEIFER in forum Africa Twin
    Last Post: 06-09-06, 01:01 PM
