Results 1 to 8 of 8
Thread: RD03 Total Engine Rebuild
    garethbrunt is offline Junior Member
    Dec 2009
    thailand
    Hi There,
    Im from the UK although I currently live in Thailand and am a fully trained mechanic. A friend here owns a 647cc rd03 that after the attempted 'rebuild' by several thai mechanics is very noisy.
    I now have the engine out and have started stripping it for him. Things noticed so far are that both timing chains are very stretched (the tensioners are at full stop and the chains still arent tight) also the oil chain is very loose indeed.
    My question to start is simply are these parts available and if so where from.
    Many thanks in advance
    Gareth
    Lutin's Avatar
    Galway
    Re: RD03 Total Engine Rebuild
    Hi Gareth
    One place to get genuine Honda parts over here is David Silver Spares -
    David Silver Spares - HOME
    Very good service from these folks.
    If you want to check any fiches for part numbers, then try these guys -
    Honda Motorbike Parts
    Stick the VIN number into their web page and away you go.
    Hope that helps.
    AlanH's Avatar
    Bristol, UK
    Not sure about Thai sources, but there are fiches on this site (see the top under Tech Data) and you can order parts from davidsilverspares.co.uk although you may need to discuss the shipping with them first.
    The oil chain is normally pretty loose on these motors but if the camchains are stretched that much, they'll make a right old noise.
    AlanH's Avatar
    Bristol, UK
    Doh! Beaten to it
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    This supplier is good but can be pricey.
    search results for "xrv650" - page 1
    Good Luck
    Dec 2009
    thailand
    Ok, thanks guys.
    Its all stripped now. The problems arent as major as fiest expected.
    The oil pump drive pulley was on the wrong way around and the chain had been rubbing on the r/h crankcase. The oil pump chain is very stretched too.
    Big ends are very lightly scored. Timing chains very stretched. No exhaust to cylinder head gasket rings were fitted?! Thats about it really. Ill start looking into parts I guess.
    Can i get big ends from the above too? I cant see them on either site? Engine code is RC31
    Gareth
    Huib Holland's Avatar
    Huib Holland is offline Senior Member
    Jun 2009
    Holland
    Wingnut's Avatar
    Wingnut is offline Senior Member
    Sep 2009
    Ireland
    Quote Originally Posted by Huib Holland View Post
    Not a bad site ,not cheap either . But good for some of the bits I couldn't find else where.
    Jonny
  1. varadero engine rebuild
    By wurzelgumage in forum Varadero
    Last Post: 26-03-09, 01:47 PM
  2. engine rebuild in south west?
    By camnz in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 20-04-08, 07:42 PM
  3. Engine Rebuild Cost
    By paultheold in forum Africa Twin
    Last Post: 01-02-05, 01:37 PM
  4. Another Engine Rebuild
    Last Post: 13-07-04, 04:21 PM
  5. Engine Rebuild
    Last Post: 20-03-04, 10:41 AM
