Results 1 to 4 of 4
Thread: Front and rear suspension and or front disks/breaks to improve breaking performance
    proxima1304's Avatar
    proxima1304 is offline Member
    Nov 2009
    Istanbul
    Hi all...!
    what could be said to improve the breaking performance of AT.
    Upgrade front disks from standard 260 to 320 EBC???
    Front and rear suspensions what would you recommend???
    Hydrolic tubes plastic to metal?
    pros cons.
    may have been covered but appreciate leads
    Kerem Cesmebasi
    Stormforce8's Avatar
    Dec 2005
    New Forest - Hampshire-on-Sea
    Re: Front and rear suspension and or front disks/breaks to improve breaking performan
    The brakes on the AT are perfectly good for the type of bike that it is - if you want to ensure you are getting the maximum performance out of them, then make sure you have good pads, and yes you could upgrade the brake hoses to braided ones as the originals even on the latest models could do with renewing.
    As for suspension - where to start.............
    There's lot's of different ways of upgrading - Ohlins, WP, Hagon, Intimators, etc......just do a search and you'll get loads of info about the various upgrades that members have done.
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    Ashley M's Avatar
    Ashley M is offline Senior Member
    Apr 2007
    Buckinghamshire
    On my @ 650 mine had a front floating disc which is said to be better but I never noticed any difference, I fitted progressive front springs which made a small improvement to the bikes handling, but the biggest noticeable change was when I got
    www.allbikeengineering.co.uk/ to rebuildmy rear shock the bike sat a good
    inch higher and was much better under braking and off road I also got a new rear disc off them
    scarfacehugo's Avatar
    Jul 2008
    London
    I also noticed the lack of stopping power when I first bought my AT. First of all I changed the brake lines to braideds, and that improved a bit the braking but not much. After that I decided to go for a bigger piston master cylinder.
    I got a DL1000 Vstrom master cylinder and that made a big difference. Not so progressive for off road, but a lot more powerfull when the bike is fully loaded.
    Suspension wise, I got a DRZ400 front end , managed to weld 2 caliper mounts and using the AT wheel, I still keep both discs in the front. Of course I had to change the springs and the oil viscosity, but after some tests, it's working fine now.
    I always go for the cheap mods...
  1. Replies: 13
    Last Post: 29-11-08, 07:00 AM
  2. Wanted - front brake disks xrv750 2000
    By miss P in forum For Sale / Wanted
    Last Post: 24-08-08, 09:52 AM
  3. front brakes disks?
    Last Post: 19-04-07, 12:39 PM
  4. front & rear suspension rebuild
    By cookiemonster in forum Dominator / FMX
    Last Post: 25-12-06, 11:52 AM
  5. Pulsing front brakes - after new disks.
    By OwenEd in forum Transalp
    Last Post: 03-10-06, 10:49 AM
