Results 11 to 20 of 26
Thread: machine gun rattle from starter relay
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: machine gun rattle from starter relay
    ..It may also be a good idea to check that the rec/reg on your bike is not faulty and killing the battery due to overcharging.
    Good Luck
    As above.
    It could equally be undercharging as well.
    Also check all your earth connections are sound, and the contacts of the master 30amp fuse under the starter solenoid while you're at it.
    Good Luck
    super@ Guest
    didnt check as it was dropping .1 a second and second abttery in a year didnt want to knacker the new battery, was down to 12. point something when I turned the lights off
  4. #13
    super@ Guest
    Also the lights seem to be really bright and I popped a lightbulb recently, so maybe the lights are drawing too much power. I had the front end off recently as well as i have changed the headlight subframe
    any ideas
  5. #14
    nomad's Avatar
    nomad is offline chicken chaser
    horwich, bolton, lancs
    Quote Originally Posted by super@ View Post
    any ideas
    regulator/rectifier sounds like it's goosed
  6. #15
    super@ Guest
    Quote Originally Posted by nomad View Post
    is there is test I can do before I fork out for another one
  7. #16
    AlanH's Avatar
    Bristol, UK
    Try this...
    http://www.electrosport.com/technica...ng-diagram.pdf
    Very bright and popping bulbs usually means regulator rectifier is dead.
  8. #17
    super@ Guest
    brilliant cheers,
    will get on that as soon as it stops raining
  9. #18
    proxima1304's Avatar
    proxima1304 is offline Member
    Nov 2009
    Istanbul
    had similar problem with a brand new battery. I bot it and travelled abt 400 kms. The next morning your w-pecker was there.
    It turned out in my case the conjektor in Turkish (rectifier ???) was the culprit. The current the alternator produced was a roof top 18V fried my 0 km batteries all along 400 km. THere was this strange electric arch sound smtime during the ride. Pullled over to check nothing. The rectifier normalizes the current at a 14.6-14,9 V interval...aything more will harm ur battery beyond use, depending on the duration of the ride.
    But the morning after the long ride the battery was not only exhausted but also had bulged on the middle...
    Kerem Cesmebasi
  10. #19
    R0vers's Avatar
    Mar 2007
    South London/Somerset
    I think that someone did a mod for a cbr600 rectifier that is a fraction of the price of the @....
    TLD2008 15.41
  11. #20
    AlanH's Avatar
    Bristol, UK
    Not CBR600 (they often have the same problem) - R1, R6 or GSXR1000 are favourites.
  1. ghost in the machine
    By shodan in forum Africa Twin
    Last Post: 27-05-08, 07:10 PM
  2. Replies: 5
    Last Post: 12-05-07, 06:34 PM
  3. Got a new machine :-)
    Last Post: 24-11-06, 10:56 AM
  4. starter relay RD07
    By paulm in forum Africa Twin
    Last Post: 27-07-06, 09:38 AM
  5. Starter relay problem
    By billy in forum Transalp
    Last Post: 10-07-06, 09:19 PM
