I have charged my battery on a trickle for the last week to make sure it was fully charged(as I thought I had a recharging issue), then put it in the bike checked the voltage with the bike off and it was 11.5. Then put the keys in the ignition and hit the start button aand all i got was a woodpecker/machine gun rattle noise from the side of the bike, on closer inspection and looking at my haynes it says the offending item is the starter relay.
Anyone got any clues, is it
loose wires
knackered starter relay
kanckered starter
kanckered rectifier
kanckered battery
kanckered solinoid
kanckered alternator
or all or a mix of the above
Any help gratefully accepted as its a bit chilly out there to go through everything
Super@
