Honda Trail Bike Forums
Go Back   Honda Trail Bike Forums > Honda Trail Bikes > Africa Twin
View Poll Results: how many parishes does guernsey have?
6 1 20.00%
8 1 20.00%
10 3 60.00%
12 0 0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Reply
  #1 (permalink)
Old 18-01-10, 05:38 PM
Doddy1's Avatar
Junior Member
fitting new ignition? xrv 750
Anybody out there tried to fit a new ignition any tips?to an xrv 750 honda i am no sparky by any means just a meer chef but willing to have a go. not to sure on how much of the bike might have to come apart?
  #2 (permalink)
Old 18-01-10, 09:36 PM
GSPD750's Avatar
Senior Member
Re: fitting new ignition? xrv 750
For starters you will need to remove the air filter housing. Once off, follow the wires from the ignition switch and disconnect at the connector. Remove the two bolts that secure the switch from below at the yoke...and voila!
  #3 (permalink)
Old 19-01-10, 06:33 PM
Doddy1's Avatar
Junior Member
HI There GSPD 750,
Does the air filter come out without the tank being removed.if the tank needs to come off how many fuel lines are there?thank you for your reply.cheers doddy1.
  #4 (permalink)
Old 19-01-10, 09:54 PM
GSPD750's Avatar
Senior Member
You never mentioned the year of your AT as their are some differences such as fuel level sensor wiring to disconnect on the L and N models.
Yes, remove the 4 screws on the plastic cover over the air filter and seat and side panels as required. Remove the overflow/vent hoses at the rear and left of the tank. Turn the fuel cock off and insert a Phillips screwdriver down the tube of the fuel tap knob and remove the tap knob.
With looooong pointy pliers release the fuel hose clamp. Remove mounting bolts and lift. It's fiddly trying to clear the frame with the fuel cock as it's a tight fit. No one is going to see the scratched paint there anyhow.
With the tank off I would follow the wires back from the ignition and try to see for yourself where they connect...just in case you don't have to take the airbox off..like Haynes sez.
The airbox removel is just bolts and tubes. Straight forward, however their are 2 clamps securing the intake tubes to the carbs. A long thin screwdriver and flashlight will locate them. When installing those clamps don't over tighten them as they will only pop off and leak. It's tricky.
Ya know doddy1...you really need a manual such as the haynes. It's no different than your cook books.
cheers.
  #5 (permalink)
Old 20-01-10, 12:56 PM
Doddy1's Avatar
Junior Member
HI Again GSPD750,
I have just found a haynes manual on ebay, so i will wait till that gets here cheers for your help. my AT is a 2001 (YE) ONCE AGAIN THANK YOU FOR YOUR TIME. Doddy1.
Reply
Tags
750, fitting, ignition, xrv
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
XR 400 ignition mce123 XR 4 29-04-09 04:00 PM
Ignition coils, are they mostly the same? boson1 Dominator / FMX 2 06-03-09 04:24 PM
Ignition Key Number Draxdon XL 10 28-02-09 09:48 PM
Ignition jpc Africa Twin 2 18-11-06 08:59 PM
No ignition Whealie Africa Twin 5 11-10-05 02:34 PM
Powered by vBulletin® Version 3.8.6
