Results 1 to 6 of 6
Thread: Side Stand Switch
    1gear1brake's Avatar
    Portland, Dorset
    Side Stand Switch
    Has anybody successfully bypassed their sidestand switch? If so, can you let me know how you did it. It is the 3-wire rotary type switch and is on an RD07A.
    Thanks in advance,
    Dylan
    futter's Avatar
    Jul 2005
    Suffolk
    Re: Side Stand Switch
    Is it not a case of cutting the wires, completing the circuit and keeping the earth, um, earthed?
    Wiff is offline Junior Member
    Apr 2008
    Nottingham
    Hi When I bypassed my switch I followed the wiring from the switch to the block connector ( green connector on mine) then got a small split pin pushed it in the back of the block connector joining the green/white wire with the green wire saved cutting the wires........ hope this makes sense I fixed my switch (expensive from Honda) I cut round the back of the switch with a Stanley knife pulled the back off in side is 2 small metal rings with 3 small springs inside the springs had worn I got an old disposable lighter and took the spring out is just the right size and cut it in to 3 put it back together and run some araldite round the back of the switch been ok up to now that was about 25000 miles ago........!!!! Hope this is of some help to you ( not very good at explaining better at getting my hand dirty and doing the job........!!!!)
    jasonbc's Avatar
    Camborne, Cornwall
    Quote Originally Posted by 1gear1brake View Post
    Thanks in advance,
    Dylan
    Did it on my Firestorm as the rear exhaust burnt through the cable, that had 3 cores in the switch (so probably same switch), 1 fed the side stand light on the dashboard and the other two i just joined together to complete the circuit left it like that for ages
    GASGAS TXT250 PRO 2006
    Portland, Dorset
    Two green wires for the switch and 1 for the dash-board light makes perfect sense. I'll disconnect the connector block and put a jumper across the two greens then. Cheers guys.
    Dylan
    tserts's Avatar
    tserts is offline AfricAddict
    Mar 2010
    Athens
    Bump on this old thread, I have my side stand switch by passed right now, but I have started off a couple of times with the stand down, I haven't fallen yet, but, being absent minded and all, I believe this thing will get the better of me sometime in the future, so I want it working properly.
    OEM part goes for 70 euros, a bit too much in my opinion, so I would like to know more about the above mentioned fixing method (I don't know if still have the switch on the bike, I bought her like this), and if someone has managed to find something on the cheapo that does the work...
    Thanks!
  1. Side stand switch bypass
    By africa twin boy in forum Africa Twin
    Last Post: 16-10-09, 01:37 PM
  2. right hand side stand
    By jamie92j in forum Transalp
    Last Post: 15-02-09, 08:42 PM
  3. Side or Main stand ?
    By peelerfart in forum Mechanical Advice
    Last Post: 31-07-08, 09:39 PM
  4. Side Stand
    By Archa in forum Mechanical Advice
    Last Post: 14-07-08, 05:00 PM
  5. Side stand
    By cip in forum Africa Twin
    Last Post: 15-05-07, 03:09 PM
