Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Worn out engine oil Bolt..help..
    paulc's Avatar
    paulc is offline Senior Member
    Nov 2009
    Carshalton,London, United Kingdom
    Re: Worn out engine oil Bolt..help..
    In a pinch you can use a spark plug
    GSPD750's Avatar
    Calgary, Alberta Canada
    Quote Originally Posted by dakarolin View Post
    Wow, this site is super fast with help replies..Its like a 24hr XRV helpdesk. Cool!
    Thanx a lot guys. Already mailed my enquiry..will update post once problem rectified.
    Sorry...but I find it odd you can't source a bolt in a city of 5 million people with close to a dozen Honda dealers. It does not even have to be made by Honda. It's only a 14 mm drain plug. Don't forget the gasket.
    Local business results for honda motorcycle dealers near Singapore
  4. #13
    dakarolin's Avatar
    dakarolin is offline NoooBeee
    Sep 2009
    singapore
    Went down a honda dealer and they didnt have stock..Asked em for other alternative and the ol' man said he had no idea..rolled eyes & walked away.
    Went down to few neighbourhood bike shops and all the mechs said in a typical
    Asian answer "This One No Stock, Old Bike, Very Hard To Find"..urgh. Some even asked me to change the whole engine oil reservoir as they dun sell it separately. Ridiculous!
    Wemoto & Davidsilvers have bolts in stock but yet to get back to me bout
    the shipping cost...
    Its not comfortable to ride when u know something is wrong...sigh..it has to be a silly small bolt..
  5. #14
    GSPD750's Avatar
    I feel your frustration. Here in the West we take so much for granted.
    You could check around and try to find an automotive style. We know it's a 14 mm but I'm not sure of the thread pitch. I would assume it's 14 mm X 1.5 thread pitch. Sure way to find out is to remove it and measure the threads with a proper thread gauge. Most mechanics have one of these gauges in their tool box. Check the following link for some ideas.
    OE Oil Drain Plugs and Washers for cars, trucks and industrial applications. (Full coverage, including oversize, piggybacks, specials, magnetic and washers to match)
  6. #15
    dakarolin's Avatar
    Sep 2009
    singapore
    Thanx Gspd..Ordered thru e-bay..very cheap. Hopefully its the same size. Now, time to hunt for new set of proper tools..
    I appreciate it everyone!
  7. #16
    paulc's Avatar
    Nov 2009
    Cant you get a nut and weld it onto the bolt,it will work untill you get a proper sump plug
  8. #17
    dakarolin's Avatar
    Sep 2009
    singapore
    Tats a good idea paulc. I'll definitely do dat if I'm on a tour. For now, the oil sump bolt is holding fine only dat I foresee difficulties in opening it during my next oil change.
    Ordered a magnetic Oil sump bolt & washer thru dis site too..looks good and cheap.
    MAGNETIC SUMP PLUGS & K&N OIL FILTER KITS
  1. Sheared engine mount bracket nut/bolt
    Last Post: 11-07-09, 09:00 PM
  2. Seized in engine bolt.
    By Andyxl in forum XL
    Last Post: 21-04-09, 03:01 AM
  3. Lower front engine mounting bolt
    By chalky4 in forum Transalp
    Last Post: 21-04-09, 02:26 AM
  4. Engine mounting bolt??????
    Last Post: 13-04-09, 08:18 AM
  5. Engine Cam Worn!
    By failsafe in forum Africa Twin
    Last Post: 28-08-07, 10:43 PM
