Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 55
Thread: Replace output shaft... feel like crying.
  1. #21
    digitalcaptive's Avatar
    Apr 2008
    Re: Replace output shaft... feel like crying.
    I'm on the Safe House List
    Ysbytymike's Avatar
    Ysbytymike is offline Senior Member
    Apr 2009
    Swansea
    Re: Engine mount.
    The person who'd owned the bike beforehand, had used 'Araldite' to stick the pieces back on and they seemed to have held ok. What I'm going to do is use 'liquid metal weld'. Gotta be better than Araldite anyway.
    Its not as bad as it sounds really, as only half of the mount has broken. So, there's still plenty of meat left there before I add the liquid metal stuff.
    Mike
    Growing old is inevitable... Growing up is optional
  4. #23
    pxlpig is offline Senior Member
    Mar 2008
    CANTERBURY
    Cool
    What brand of liquid metal are you thinking of using?
    I only ask as i haven't had any luck with it before in the past... probably me doing it wrong.
    If i can get it to work it may be really handy stuff to have, I have heard reports of people using it on the output shaft..... surely it would not hold up to the torsional forces??
    2000, RDO7, Black, Arrow Exhaust, Black Powerbronze screen, Corbin Seat, Hagon Shock, Black Crash bars, Garmin Nuvi, and a Shoei Hornet.
  5. #24
    R0vers's Avatar
    R0vers is online now BLUE 1999 xrv750x
    Mar 2007
    South London/Somerset
    Quote Originally Posted by pxlpig View Post
    Cool
    dont try this... its the wrong use for this product - it could be dangerous even thinking if using this for the output shaft...
    you are on the right track with a rebuild.... good luck and looking forward to seeing your rebuild thread when you are ready...
    TLD2008 15.41
  6. #25
    Mar 2008
    CANTERBURY
    Quote Originally Posted by R0vers View Post
    That's exactly what i thought
    Some things you hear huh.....nuts!
  7. #26
    jamespayne is offline open to offers
    uxbridge
    [QUOTE=R0vers;438869]dont try this... its the wrong use for this product - it could be dangerous even thinking if using this for the output shaft...
    hi chaps, I need to know, why is this dangerous?
  8. #27
    GSPD750's Avatar
    Calgary, Alberta Canada
    [quote=jamespayne;442519]
    Dangerous was the wrong word he used...I think he meant stupid.
    Come on now folks...no two part epoxy adhesive is going to hold a steel sprocket onto a shaft.
    Their is only one liquid metal.
  9. #28
    Xman is offline Senior Member
    Feb 2008
    Wilts
    Just popping on a new set of sprockets and chain, checked the output shaft and the splines are down to about 1mm....... had a chat with a garage mate and he says that to replace the output shaft is a complete engine strip and is gonna cost about £1000 (parts and labour) this would include, new gaskets, fluids, output shaft redo camchain etc etc.
    As an alternative he has suggested I sell my beloved @ and getting another.
    As this was my first bike 9yrs ago and with only 40,000 miles on the clock and loved dearly i really don't want to do this.
    Ok for the question that i hope you guys can help on:
    A) can i replace the shaft myself?? Be the fisrt time i have done ANY mechanical work of this scale.
    B) how much does it cost for a new shaft and where do you get one from??
    Hope you folks can cast a bot of sunshine on this gloomy subject.
    If you're after a quick cheap fix and the rest of the engine is fine, just fix on a new sprocket by welding a few tacks on the outside. A good welder should be able to mig weld quickly with out too much heat going down onto the drive shaft seal. Then in the future if you want to replace it just grind off the welds and repeat.
    I know it sounds a bit crude, I am an aircraft technician by trade and I hate to bodge things, but it doesn't affect anything else, and you can be on your way for a fraction of the price of a gearbox rebuild.
    PS...and remember to run your chain tension correctly in the future, as worn drive shaft seals are almost certainly caused by a too tight chain or old Oring chain with tight spots.
  10. #29
    uxbridge
    [quote=GSPD750;442587]
    Quote Originally Posted by jamespayne View Post
    Oh. Guess what I did last summer...? And its still there. I used a product called Quicksteel. I roughly made up new splines, and before it set as hard as steel, like the packet says it should, I filed it down to the correct size and shape. Robert is now your fathers brother, new splines. No rebuild, not much fuss, a steady hand and most of an afternoon. Just fitted new chain and sprockets today, same shaped splines, unbroken and in place. Output shaft. Done.
  11. #30
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Quote Originally Posted by GSPD750 View Post
    That's the baby you want.
    00-074
    HONDA PULLER 22x1.5
    £7.73 inc. vat@17.5%
    Price: £6.58 (Excluding: VAT at 17.5%)
    If anyone wants me to buy this as a forum tool that can be shared around for those in need then just shout. I'll buy a puller as well if someone tells me which one is required.
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
  1. Should I replace my output shaft!!!!!
    By kitped in forum Africa Twin
    Last Post: 21-07-09, 08:24 PM
  2. Output Shaft Seal
    By vinas in forum Africa Twin
    Last Post: 20-06-09, 05:54 PM
  3. transalp output shaft
    By nathan35uk in forum Transalp
    Last Post: 13-05-09, 06:13 PM
  4. Output Shaft
    By JamesJoyce in forum Africa Twin
    Last Post: 28-05-08, 07:56 AM
  5. XRV 650 output shaft gone
    By expat Stu in forum Africa Twin
    Last Post: 31-07-07, 10:24 AM
