Results 1 to 10 of 11
Thread: Stainless exhaust needed
    rick's Avatar
    rick is offline Member
    Apr 2009
    yorkshire
    Hi
    I'm in need of a stainless exhaust for my 07
    The first place to start would be "best and cheapest"
    I’ve got a Laser on my 04 which seems to do the business
    Any ideas or preferences or ones to leave alone
    Rick
    digitalcaptive's Avatar
    Apr 2008
    Re: Stainless exhaust needed
    I know a few guys run the Motad Venom cans, they sound really nice and are usually on ebay for £89.00 inc link pipe (sods law says there's none there now ),
    Both myself and Wigan Chris run the Quill T3 cans, again nice note and come in at about £200.00 fitted, a very professional bunch of guys
    Quill Performance Motorcycle Exhausts :: Official Site ::
    Quill Exhausts
    Unit 18, Golborne Enterprise Park
    Kidglove Road
    Golborne
    Warrington
    WA3 3DP
    I'm on the Safe House List
    The Taffia's Avatar
    The Taffia is offline Member
    Sep 2007
    Aberdare South Wales
    Just bought and fitted a motad venom - £89 on e bay. sounds great, easy to fit but make sure you specify what type of link pipe you require, pre or post 98.
    dazzerrtw's Avatar
    dazzerrtw is offline Senior Member
    Feb 2007
    West Yorkshire
    Hi
    same as Taffia
    I fitted a Venom exhaust .it's very light compaired to the om can.
    It's stainless steel and sound's very good.
    You can remove the baffle if you wish,That said I left it in
    I won it on ebay and it arrived the next day.
    this number will take you to the seller who as one for sale on ebay at the moment.
    160401636125
    Dazzer
    Ysbytymike's Avatar
    Ysbytymike is offline Senior Member
    Apr 2009
    Swansea
    Sorry Rick, don't wanaa hi-jack your thread but seem pointless starting a new thread to ask if anybody can help find a S/S exhaust for my (92) RD04.
    Mike
    Growing old is inevitable... Growing up is optional
    dazzerrtw's Avatar
    Feb 2007
    West Yorkshire
    Quote Originally Posted by Ysbytymike View Post
    Mike
    if you put the number I posted above in ebay,it will take you to the chap selling the stainless Venom exhaust's for most Africa Twin's
    Ysbytymike's Avatar
    Apr 2009
    Swansea
    Thanks for that M8 but looking at the advert, he's been producing can's for post 93 bikes where's mines a (92). I have sent a message to find out if he can help but will have to wait and see.
    Thanks again
    Mike
    Zenarchy's Avatar
    North East UK
    I contacted motad last year to ask if they'd be able to supply link pipes for the rd04. At the time they had no plans to do that (Maybe you'll be lucky and they've changed their mind if enough people have asked by now though).
    Eventually I bought a used motad can from a nice man on this forum. The link pipe can be cut and welded to make a reasonably good fit.
    I don't have very good photos of this to hand unfortunately, but this one shows the weld and pipe fairly well (just under the pillion peg - it's hidden behind there quite well and you can't see the join unless you get down low).
    I had this done at a local bike shop that also make their own cans and pipes. Involved a little compromise getting it into exactly the position I wanted due to needing to work with the existing bends, but he did a great job considering what he had to work with.
    The link pipe actually fitted (albeit forced into place a bit) before I had this done, though it was tricky to get into place, and because of the bends it stuck out at a bit of an odd angle putting the end can closer to the luggage rack than I was comfortable with until I had it modified.
    Having the link pipe cut and welded back this way might still turn out to be a lot cheaper than buying a specific RD04 stainless exhaust. If you do this if you can find somewhere to take the bike to so the can size it all up, it'd probably be better, so you can check it clears any luggage rack you might have sufficiently, and so it's not going to hit the brake caliper when the suspension compresses.
    There's some photos of an RD04 bike a guy called Chad here added a motad can to and he seemed to have managed to get it pretty much perfect without having to go to these lengths if you do a search (I think he just trimmed a little off one end), so there seems to be some variation in the link pipes (that wasn't possible with mine).
    I think there's a post here somewhere from someone who found an ebay cbr link pipe that fitted on without modification (or little modification) too. Link pipes for sports bikes often go for peanuts on ebay (though I can't remember the exact model number it was they used - will be here if you do a search I think).
    Ysbytymike's Avatar
    Apr 2009
    Swansea
    Thanks for that M8. Sounds like a lotta work. With a bit of luck they'll be able to get my original one repaired for the time being.
    At least I'll be able to se the bike whilst trying to source another way of doing this.
    Thanks again.
    Mike
    Zenarchy's Avatar
    North East UK
    Thanks again.
    Mike
    It wasn't much work really. The guy was very quick and had the link pipe cut and welded together again in only a few minutes (it took a bit of time sizing it up against the bike before doing that to decide where to cut it to get it as close as possible to where I wanted it, then mounting it back on the bike afterwards though - that's where most of the time went).
  1. Stainless upgrade
    By Wigan Chris in forum Africa Twin
    Last Post: 27-10-09, 09:12 PM
  2. Help, new exhaust needed.
    By IanS in forum Transalp
    Last Post: 12-01-09, 07:59 PM
  3. stainless front exhaust pipes?
    By MCsanandreas in forum Transalp
    Last Post: 09-08-08, 11:25 AM
  4. Arrow Stainless Exhaust
    Last Post: 15-09-06, 05:55 PM
  5. Stainless Steel Exhaust
    By Stormforce8 in forum Africa Twin
    Last Post: 05-01-06, 08:36 PM
