Results 1 to 6 of 6
Thread: Noisy Facet Fuel Pump
    The Taffia's Avatar
    The Taffia is offline Member
    Sep 2007
    Aberdare South Wales
    Took the the AT out for a spin today, first time for about 2 months. Have noticed that the facet fuel pump is ticking rather loudly. Iv'e done about 2,000 miles since fitting it. Is this normal?
    taffy's Avatar
    taffy is offline Senior Member
    cork / cardiff
    Re: Noisy Facet Fuel Pump
    hi faffia, mine made that noise when not getting enuff fuel the pipe was kinked, and again it happend to tell me to turn to reserve.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    As above, sounds like a fuel starvation problem to the pump - I've heard it once or twice before switching to reserve.
    Check yer pipe work
    Steve T
    GSPD750's Avatar
    Calgary, Alberta Canada
    Not uncommon.
    Noisy Facet pump
    The Taffia's Avatar
    Sep 2007
    Thanks for the tips guys I'll check it out when I get a chance
    The Taffia's Avatar
    Sep 2007
    Finally had the time to get to the bottom of problem, firstly there was a slight kink in fuel line probably after changing fuel pump, but also the tank was nearly empty so turned onto reserve. Either way problem fixed.
  1. Noisy Facet pump
    By vinas in forum Africa Twin
    Last Post: 15-08-09, 08:56 PM
  2. Facet Fuel Pump, Fuel through the roof
    By pxlpig in forum Africa Twin
    Last Post: 12-04-09, 07:22 PM
  3. Facet fuel pump - help please
    By Sir Royston in forum Africa Twin
    Last Post: 18-11-07, 11:20 AM
  4. Facet fuel pump
    Last Post: 06-06-07, 10:29 PM
  5. Facet Fuel Pump
    By DaveS in forum Mechanical Advice
    Last Post: 19-02-06, 12:55 AM
