Results 1 to 6 of 6
Thread: front sprocket not bolted????
    irideforlife is offline Senior Member
    Jan 2010
    merthyr tydfil
    Been using my AT for over 7years as a daily means of transport apart from the last two years and have decided that i need to use bikes daily again as I miss them. Done over 2000 miles on my At this year as pleasure rides but when I started using it as daily tansport again I have noticed a strange grinding noise on over run. Thought it was the chain rubbing. Ordered a new one as getting near end of life. Today really bad so took of front sprocket cover. No bolts holding it on. Its been grinding the front sprocket case. I normally do the chain replace myself but last time paid for it. Cant find receipt and was several years ago as not put much mileage on it. Today I was doing 70 on the motorway without a bolted front sprocket. Know there is not much I can do as been to long since bike shop fitted it but will never use a dealer again.
    DRLANER's Avatar
    DRLANER is online now Do you have any cheese?
    Here, There, Everywhere!! (But mostly Here)
    Re: front sprocket not bolted????
    It's them welsh mechanics!! Gaffa tape and zip ties are standard tools!
    Not to offend any welsh person on this forum or in the immediate vicinity of course!
    GSPD750's Avatar
    Calgary, Alberta Canada
    Proper procedure in the shop manual is to apply a threadlock or locktite on the threads of those 2 bolts.
    dazzerrtw's Avatar
    dazzerrtw is offline Senior Member
    Feb 2007
    West Yorkshire
    Quote Originally Posted by GSPD750 View Post
    I think they must have been left out.I don't think there is enough room form them to work lose and drop out because the sprocket cover is so close to the sprocket itself.
    There is also a locking tab that goes on then turns to lock the tab inplace before the 2 bolt's are replaced.
    I would guess that they forgot to refit them
    I have had problems with dealers doing services on my bike's in the past.
    one which cost me half of my holiday because they did not refit the cam chain tensioner correctly.
    Now I do all my own work it's a good excuse to get out the house work and get into the garage
    Dazzer
    All very well but if those bolts don't fit the bike the thread lock will not do any good.
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    Have you had a look at the splined shaft...might be a bit munted?....
  1. 17T Front Sprocket
    By stingray in forum Africa Twin
    Last Post: 16-06-09, 07:42 AM
  2. Front Sprocket
    By Cabby in forum Transalp
    Last Post: 02-05-09, 03:53 PM
  3. front sprocket
    By ADE THE BLADE in forum Transalp
    Last Post: 21-04-09, 10:02 PM
  4. Front sprocket
    Last Post: 14-08-07, 10:39 AM
  5. Front sprocket
    By Kerr in forum Transalp
    Last Post: 21-07-06, 08:07 PM
