Last Autumn the speedo on my RD04 stopped working suddenly. The cable looked pretty corroded, so I replaced it.
All was fine for a couple of hundred miles and then it stopped again.
I removed the front wheel and took a look inside the little gearbox thingy. Everything looked fine, but following advice on here, I bent the lugs on the circular drive that sits against the wheel hub, just to make them sit up a little more. I also noticed that the leading edge of the lugs on the nylon drive were worn.
I assembled everything, but no joy.
I had a spare wheel, so I dismantled that and noticed there was an o-ring inserted behind the circular drive ring (with the lugs). Working out that this must push the lugs closer to the nylon drive cog, I swapped it onto my original wheel. It worked for a couple of hundred miles and then the speedo stopped again.
(I keep a record of fuel economy based on miles between fill-ups, so you can imagine how annoying this was, completely buggering up my stats!)
This time I bought a complete gearbox unit from eBay and installed that. The nylon cog looked like new, with no wear on the lugs at all. I took the o-ring out at this stage.
Everything was fine for a while and then, guess what, it stopped working again.
When I stripped everything down, I found the nylon cog completely stripped bare.
So I took the original nylog cog, pared the leading edges of the lug down so they were now at right angles, stuffed everything with grease and put it into the newer gearbox unit.
Again, everything worked for a while. Until yesterday, when it stopped again.
I've forked out nearly £21 for a new nylon cog, so before I strip the speedo drive down yet again and fit the new bit, has anyone any idea what might be causing the problem?
Bear in mind I've used two different gearbox units, two different nylon cogs, two different metal drives (with and without o-ring), plus one new cable.
Thanks in advance for your words of wisdom and experience.
