Results 1 to 10 of 10
Thread: Brake calipers clean them!
    barftone's Avatar
    Apr 2005
    Bath, England
    Just pulled my calipers apart and if you have been riding this winter get em cleaned soon. I promise you will regret it if you don't bother. I find a Dremel type tool useful.
    Mutley's Avatar
    May 2004
    Top of the hill
    Re: Brake calipers clean them!
    I did mine a couple of months ago and they were unbelievably dirty/cruddy. Will definitely do them again soon ready for my new brakelines off KnobblyWobbly
    There's been a couple on lately talking about putting NTV calipers on Ats, perhaps the way to go as originals seem to be made of recycled tat!
    TWIN BURNER's Avatar
    TWIN BURNER is offline Senior Member
    Mar 2007
    Rhondda South Wales
    Had mine done today including new pads allround and 16000 mile service All I need now is some sunshine or and time to ride it
    2000 RWB @
    1978 Honda Britain
    199* Yamaha 250 4x4 Timberwolf
    2003 Mondeo estate ghia x tdci
    2003 Elddis Odyssey Touring caravan
    ADE THE BLADE's Avatar
    Jan 2009
    up there !
    Quote Originally Posted by TWIN BURNER View Post
    saw you on your honda britain few weeks back in caerphilly ( morrisons ) doing yer tyres !..........red bike ? you or that woman had no change...correct ?
    Mar 2007
    Rhondda South Wales
    Quote Originally Posted by ADE THE BLADE View Post
    Nope not me mines blue and is in bits on the bench getting a full rebuild
    2000 RWB @
    1978 Honda Britain
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Quote Originally Posted by barftone View Post
    SECONDED!
    I did all of mine yesterday, during the brief break in this depressing rain!
    Haven't used my bike for over a month, and it has sat outside in all it's dirtiness under the snow. Went to try it the other day and it was locked solid!
    Pistons in all the calipers had seized, but luckily, as I've had them apart so may times they're a doddle to do, and I did all three in less than 2 hours just as the rain started again.
    Once again, pistons were seized due to corrosion in the recess where the dust seal sits. The rest of each caliper was fine.
    I remove all the seals, then scrape out the recess with the cranked end of a suitably sized allen key. As mentioned, the little skinny wire brush wheels which come with Dremels or other hobby drill things are good for doing the job, but just take it gently and make sure you only clean out the recess for the seal.
    Cleaan up the caliper with brake cleaner, then lube all the seals and pistons with fresh brake fluid before re-inserting them.
    Today's interlude in the rain saw me whacking out the headrace bearings (and god they were in an awful state) and getting halfway again before the heavens opened up again.
    Once the headraces are done I need to do the following;
    Rear wheel bearings
    Rear shock linkage re-grease
    Remove uprated clutch springs and put originals back in.
    New clutch cable
    Oil & Filter
    I'm praying for a let-up in this godforsaken weather!
    Mutley's Avatar
    May 2004
    Top of the hill
    ''Remove uprated clutch springs and put originals back in.''
    Hi Bob, May I ask why you are taking these out again? I was thinking perhaps a set of these might freshen up my clutch..
    TA! Shel
    BobA's Avatar
    Sussex Riviera
    Quote Originally Posted by Mutley View Post
    TA! Shel
    A year or so ago I thought my clutch was knackered, so bought new plates and uprated springs as I was doing the HUMM on my AT.
    Fitted new plates and springs, and the clutch was still slipping!!!
    I'd been a fool and just ASSUMED without checking, and all my woes were down to a binding (knackered actually) clutch cable.
    I quickly fitted a new cable and all was well, although there was significantly more effort required with the left hand because of the uprated springs.
    Clutch has gradually got a lot worse, and the Hulk would have problems with the clutch lever effort required in London traffic I swear! I think the stiffer clutch springs have caused faster wear or stress on the standard clutch cable, and this combined with the springs is making it annoyingly hard.
    Gonna be putting the standard springs back in and fitting a new cable.
    Pussyhorse's Avatar
    Essex mate
    Edited due to my own stupidity
    Mutley's Avatar
    May 2004
    Top of the hill
    Thanks Bob
    I'll have a look at another cable and get it routed properly this time. The current cable has been rerouted a couple of times already!
    Cheers Shel
  1. Brake calipers
    By XRVOslo in forum Africa Twin
    Last Post: 28-08-09, 06:55 PM
  2. TA 650 Brake calipers
    By tizzi in forum Mechanical Advice
    Last Post: 14-04-09, 02:43 AM
  3. brake calipers
    By 4x4biker in forum Africa Twin
    Last Post: 18-12-06, 11:25 AM
  4. Brake Calipers
    By DaveS in forum Africa Twin
    Last Post: 11-01-06, 07:41 PM
  5. Clean brake pistons
    Last Post: 14-02-05, 06:30 PM
