Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Throttle cables...
    Lord Stig's Avatar
    May 2004
    West Lothian
    Re: Throttle cables...
    Yes - I removed mine when I still lived in Portsmouth and if you want it it's probably still in the drain I threw it down in Cleveland Road . But wait - you obviously did the sensible thing and binned it too! Why did Honda bother....?
    psi's Avatar
    psi
    psi is offline a tool
    Jun 2009
    Tampere, Finland
    The white thingy is a b**ch to install "correctly", afair lower cable tends to slip but will not hinder installation, just jam & eat at the guide. Once correctly installed, the throttle was snappy for me too (was tight when bought from previous owner).
  4. #13
    CaBRita's Avatar
    CaBRita is offline Member
    Oct 2009
    Lisboa, Portugal
    Hello, I bought my '97 AT a couple of months ago and always found the throttle a bit stuck, compared to my CBR600.
    Can anyone provide a photo of that "white thing in the throttle grip"?!
    It seems so simple that I'm not figuring out what that is.
    Sure will try without it as soon as I identify it.
    Thank you and Best Regards from Portugal!
    Luís Cabrita
    '93 NSR50
    '99 CBR600
    '97 XRV750
  5. #14
    WheelieSparks is offline Senior Member
    Jun 2009
    Portsmouth
    Quote Originally Posted by CaBRita View Post
    Luís Cabrita
    '93 NSR50
    '99 CBR600
    '97 XRV750
    Hi, as soon as you take the throttle housing apart you'll see a white plastic insert where the cables run... this is the bit that seems to cause the problems.. I removed mine and the throttle is 100 times better now.
  6. #15
    Ysbytymike's Avatar
    Ysbytymike is offline Senior Member
    Apr 2009
    Swansea
    Here you go Cabrita..
    The larger of the two is off the AT and the smaller is off my XR250. Same design on both bikes just a difference in size. Best place for them in in the bin.
    Hope this helps.
    Mike
    Growing old is inevitable... Growing up is optional
  7. #16
    CaBRita's Avatar
    Oct 2009
    Lisboa, Portugal
    Hi,
    Could not resist after these posts and have just returned from my garage where I've removed the "white thing in the throttle grip" of my AT.
    It is now much much better , even with the handle bar in full lock it is not sticky - it was locking in this position before!
    Thank you for the simple yet very useful tip!
    Luís Cabrita
    '93 NSR50
    '99 CBR600
    '97 XRV750
  8. #17
    HZolio's Avatar
    HZolio is offline Junior Member
    Dec 2009
    Portugal
    Hi,
    Luís Cabrita
    '93 NSR50
    '99 CBR600
    '97 XRV750
    Cabrita, eu não o tirava! Dá trabalho a colocar, mas poupa-te os cabos não os trilhando!
    OR: It's a p@in in the ass to install it correctly, but once done works faultless and save the cables from the aluminium! Mine do work (in situ ) !!!
  1. Longer Brake, Clutch and Throttle Cables / Hoses
    By slanty in forum Everything Orange - KTM
    Last Post: 22-06-09, 10:07 PM
  2. Africa Twin RD07 Genuine Honda Throttle Cables New
    By Hinch in forum For Sale / Wanted
    Last Post: 08-04-08, 11:21 PM
  3. Cables!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    By ABZ in forum Africa Twin
    Last Post: 04-01-08, 03:10 PM
  4. Longer clutch and throttle cables
    By lootch67 in forum Mechanical Advice
    Last Post: 19-09-07, 10:15 AM
  5. Throttle Cables?
    By gibbo in forum Africa Twin
    Last Post: 27-04-05, 01:06 PM
