I'm not Fabian but I'll chime in...If you look closely in the first pic you will see the letter "A" (anode) and the letter "K" for (cathode) Don't ask me how you get a 'K' out of cathode but thats the way I see it.
The yellow 'jumper wire' comes from the cathode side of the diode marked "K" and goes to the blue/black wire. In the 2nd and 3rd pic the diode is flipped around upside down which may be confusing. The other solder joint which Fabien explains is of course the anode side of the diode marked "A" which goes to the ground on the output switch (negative side of the coil).
That's the way I see it.
So no wire cutting, just the + wire stripped a bit to solder the diode in there.
Right?
Thanks!
I've been reading this: Transient voltage suppression diode - Wikipedia, the free encyclopedia
Is this similar to what Fabien used?
They look rather different...
And what about the type of diode?
Can you please help?
Thanks![]()
I did this on the weekend to my bike and a friends bike. It was easy peasy. I did mine with the pump attached to the bike but my mate had removed his pump as it needed a good clean and some attention given to leveling the contacts which were badly pitted after 20,000 miles.
I was a lot easier to do it off the bike.
You can get the diode in the UK from RS components but I think you need a account and I had to buy a pack of 5 as that was the minimum order but that only cost about four quid.
Make sure you insulate well as all your work will be for nothing as the pump won't work at all if there's a short.
Here is the one I used: FAIRCHILD SEMICONDUCTOR|RURP860|DIODE REDRESSEMENT DOUX 8A | Farnell France
