Results 1 to 10 of 11
Thread: tripmaster.. improved?
    foz1969's Avatar
    Jun 2009
    ATiC - Honda Africa Twin Homepage interesting... anyone tried?
    1gear1brake's Avatar
    Portland, Dorset
    Re: tripmaster.. improved?
    It's one of those things that I've always wanted to try but never got around to. It would be useful to have a kph readout for those euro trips.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    My first @ was an import, with kph clocks. I did the resister mod to get mph up on the tripmaster, but just on the trips. Getting a physically small enough resister to go onto the board an not interfere with anything else was a real pain, but I managed. Couldn't find those surface mounted resisters anywhere, so i used a normal, but physically small, tubular type.
    I didn't bother with the speed readout mod because I didn't need it. Plus with both mods incorporated, the tripmaster could, allegedly, freeze up.
    There is / was someone on this forum that has done both mods though.
    Steve T
    nomad's Avatar
    nomad is offline chicken chaser
    horwich, bolton, lancs
    had the kph speedo conversion done on mine and as 1gear said it was handy to have when riding in france
    mine never froze on me but i believe if you press the trip reset while in speed mode it will
    my mates wife did the conversion for me as she worked in an electronics company assembling circuit boards but any radio shack/electronics shop should be able to do it for you
    romeo one's Avatar
    romeo one is offline Senior Member
    May 2005
    A small village in Mallorca
    I did mine three years ago,works great,I use it quite a lot up and down to the UK.
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    I did the KPH to MPH mod a few yrs back on a black 99 @T, due to my lack of resistors I simply joined the two points on the board, worked fine! Not recommended as a surge could in theory take out the board but as wanted rid of the kph clock any how, it was worth the gamble!
    tserts's Avatar
    tserts is offline AfricAddict
    Mar 2010
    Athens
    I had no idea this was possible, very cool tip!!
    I think I'll give it a go..
    foz1969's Avatar
    Jun 2009
    While replacing the speedo bulbs i thought i'd have a go at doing the tripmaster modification, went to maplins to buy 10k ohm resistor (17p) cut the ends down to 7/8mm, bent them at 90deg. soldered and left it slightly proud(enough space when reassembled). Turned the ignition on... BINGO!
    Trouble is it's in kmh, it says to put/remove resistor in order to have mph/kmh. Mine is a UK model, with a resistor already in the mph slot, I presume this is the piece you need to remove to enable the speed to be shown in mph. Advice modifiers please.
    PerfectStranger's Avatar
    PerfectStranger is offline Senior Member
    Mar 2008
    Lisbon, Portugal
    Quote Originally Posted by foz1969 View Post
    I would think that with the resistor soldered at "mph" place, you have the option to switch between kph and mph at the press of a button...
    Mine only has the speed mod
    foz1969's Avatar
    Jun 2009
    pressed all the buttons(including re-set, while in speed mode... DOH, easy total reset) STILL IN KMH! Hmmmm?
  1. Tripmaster
    By c13tay in forum Africa Twin
    Last Post: 25-06-09, 12:01 PM
  2. Tripmaster on RD 04?
    By andras in forum Africa Twin
    Last Post: 13-01-09, 07:15 PM
  3. Tripmaster......... again!!
    By g45her in forum Africa Twin
    Last Post: 02-01-09, 05:13 PM
  4. Tripmaster Mod
    By Wigan Chris in forum Africa Twin
    Last Post: 25-11-08, 07:27 AM
  5. Tripmaster... again
    By ddcristi in forum Africa Twin
    Last Post: 31-07-08, 10:01 PM
