Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 57
Thread: 97 AT won't run properly...
    WheelieSparks is offline Senior Member
    Jun 2009
    Portsmouth
    Well finally got the bloody thing MOT'ed today after a lot of aggro, but now it wont bloody run!! Feels like it's over-fueling? the idle is very low and raising it on the throttle butterflies makes it act funny. Now it seems to bog down when accelerating and only does about 40mph max, it cuts out when I slow down.
    Any ideas?? It has a facet fuel pump fitted if thats of any importance.
    REALLY want to go ride tomorrow so any suggestions?
    are there any adjustments on the carb that could affect its running?
    Lutin's Avatar
    Galway
    Re: 97 AT won't run properly...
    Are the chokes stuck on?
    Wild guess.
    Jun 2009
    Portsmouth
    Wild guess.
    Hmmmm I don't think so, the choke lever doesn't appear to do too much really (I assume that fully out is choke off and into the bar is choke on? ) it doesnt do much, but if I pull it in the bike does cut out so I assume it is working and not stuck on.
    Wondering if it could be the fuel, its been stood for a few months, it ran fine this morning though however I did put some petrol I had in my garage in, it's not all that old though guess I should drain the tank, check the filters not blocked then fill up with fresh petrol as the next step.
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    I know i`vw got the Alp but
    does it start at all when the engine cold? if not it aint the choke sticking
    if it starts cold then when hot won`t start its prob the carb choke plungers stuck on , common prob easily fixed just unscrew plastic nut thingy and squirt with wd40 while pull/push choke.
    have you checked the easy to get at plugs to see if its getting "overfueled"
    take it that it ran okay before -noticed you only just got it from another member, have you tried him as most people on hear are real friendly like
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    drain the carbs into a small bowl and see what **** comes out, prob blocked jets-major strip down = lost weekend
    do you have a haynes manual? I`m local and part of the borrowers guild
    Jun 2009
    Portsmouth
    It starts hot and cold, but idles really low then is unrideable as it just bogs too much, not entirely sure how to tell if somethings over or under fueled when riding, but it just seems to be struggling a lot, won't go fast, won't pull away properly and likes to cut out as soon as I let the revs drop... however it will idle.....
    I'm going to go and drain all the petrol, check the fuel filter and then top up with fresh fuel and see if that makes any difference.. I'll also check the choke lever isn't sticking and spray with WD40 as you suggest.
    Weird this is it was fine yesterday.
    Does the reserve tap pipe sit quite high in the tank??? It's got petrol in for sure but not a great deal, wondering if the reserve pipe sits fairly low and isn't picking up enough fuel hmm.
    tangle's Avatar
    tangle is offline Member
    Feb 2010
    Brighton
    How old do you reckon that petrol actually was? I have an interest because I left some for 10+ years and it was like treacle - glued up everything, jets slides plugs etc and needed a complete strip down. Anyhow, here's an Oz guide that I found sort of interesting.
    How long does fuel last?
    This is an important question when you’ve got a car that’s rarely driven or you have fuel stored in drums. The last thing you want is a tankful of ‘off’ fuel that can damage your fuel system or possibly even kill your engine.
    According to Shell Australia’s Technical Advice Centre Manager, Warren Scott, you can generally store fuel in a sealed container for around six months before it starts to deteriorate. This assumes it’s kept relatively cool and away from direct sunlight.
    “But if the container is not properly sealed or it’s repeatedly opened, [fuel] will start to evaporate and you lose some of the light components in the fuel,” Mr Warren says.
    Those light components include highly important butane. As these components are lost, the fuel loses its volatility. Mr Warren says this makes the car difficult to start.
    In warm conditions, fuel is especially prone to oxidisation which causes lacquer and gums to form. As a result, the fuel turns dark in colour, loses its clarity and smells like paint stripper.
    Gary Whitfield, Senior Fuel Chemist at BP Australia, says that in the right conditions, fuel can last up to 12 months. But once the container is opened, the fuel will start to degrade.
    “Once the seal is broken, a vapour space is formed in the container and the fuel will start to deteriorate more rapidly,” he says.
    Okay, so what about fuel that’s left in your car’s tank for a long period of time?
    Mr Whitfield claims fuel in a car’s tank can last for up to four weeks before it becomes considerably denser. When this happens, the engine is effectively over-fuelled (without any change in injector pulse-width) and there’s an increased chance of carbon deposition onto spark plugs and inside the combustion chamber. This can cause driveability problems such as stutters and misses.
    “Regular unleaded fuel will lose a small amount of octane over time but in our low-sulphur and high detergent Ultimate fuel it might increase very slightly. It might increase 1 RON in four weeks – but it’s not something I’d bother chasing,” he says.
    “Keep in mind that typical variation in BP Ultimate is 98 – 100 RON while normal unleaded ranges between 91 – 93 RON.”
    Mr Warren says that in most cases, it’s only when fuel is left in the tank for several months there’s the risk of engine damage. This is much more likely to occur in cars running dual LPG/petrol systems.
    “By this time the fuel will have gone dark and gummy and can clag the fuel pump, filter and injectors,” Mr Warren says. It can also leave a lacquer deposit on the inside of the fuel tank which is difficult to remove.
    In addition, it’s important to be aware that fuel brews – specifically fuel volatility - varies on a month to month basis. Standards vary from state to state but, generally, volatility is reduced during summer months to reduce evaporative emissions. Mr Whitfield says this typically makes the engine slightly harder to start but there is no change in octane.
    Lachlan Riddel, proprietor of Gold Coast based tuning company ChipTorque, frequently dyno tests cars which have not previously been driven for several weeks.
    “On the fuel mix we have in Queensland, I think fuel in a car’s tank is starting to go off in around three weeks,” Mr Riddel says. “We can tune a car, put it away for three of four weeks, come back to it and it will be either closer to detonation or less likely to make the same power.
    “I think local fuel is brewed to reduce evaporative emissions in warm weather and, maybe because of that, fuel really goes crappy in eight to ten weeks. By that stage, the fuel is extremely prone to detonation.”
    Interestingly, Mr Riddel hasn’t noticed the engine becoming harder to start but the effect on octane is pronounced.
    Similarly, the General Manager of Melbourne’s Advanced Vehicle Operations, Steve Coates, believes fuel tends to go off in a car’s fuel tank quite quickly once it’s a couple of weeks old.
    “After a couple of weeks not driving a car, I find that it will be closer to detonation than it was at the time of tuning on the chassis dyno,” he says.
    “And the brand of fuel seems to make a difference as well – I find that Mobil and BP products are probably the best after being stored but Shell Optimax is really good when it’s new."
    Clearly, there are some important factors to keep in mind when storing fuel in a container for several months or when parking your car for a few weeks.
    Our recommendation is not to run the engine at high load with fuel that’s been in the tank for any more than three of four weeks and it’s a good idea to add at least 25 percent fresh fuel to the tank every few weeks. This will help ensure there are no fuel-related driveability problems or detonation and will reduce the chance of lacquer building up inside the tank.
    Jun 2009
    Portsmouth
    The fuel has probably been in there for about 3 months at a guess... I've just drained it, it didn't look any different to normal petrol to be honest. I've topped up with some fresh petrol and it's no different... the fuel filter doesn't appear to be blocked and spark plugs are okay, black.. but they weren't excessively wet.
    It ran fine yesterday and seemed okay this morning too?!? the only thing I've done in that time is all new gaskets on the exhaust (as it didn't have any and was blowing from every single joint, the lower collector box is rotten and needs replacing ) but I rode to the bike shop after that and it seemed fine too, it's just since picking it up from honda it's gone completey fooked!
    Currently wishing I'd spent the extra on an 950 Adventure
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    Sounds to me as if the chokes are stuck on.
    Check a spark plug from both front & rear cylinders for colour. If either or both are wet & black, your chokes are stuck on.
    1gear1brake's Avatar
    Portland, Dorset
    Quote Originally Posted by Steve T View Post
    Me too. The choke plungers need cleaning and lubing, and clean or replace the plugs (only 2 quid each at Rugged Roads last time I checked - bargain!). Blackened plugs won't be giving clean sparks. Stick with it. The KTM has got nothing on the mighty Africa Twin.
  1. Replies: 8
    Last Post: 12-07-08, 11:33 AM
  2. Not charging properly...
    By skellem in forum Mechanical Advice
    Last Post: 02-11-07, 12:51 AM
  3. Properly Mad
    By Rubberchicken in forum Other Bikes
    Last Post: 31-07-07, 07:20 AM
