Results 1 to 10 of 10
Thread: Fog Lights
    Nicko is offline Junior Member
    Sep 2007
    York
    Fog Lights
    Hi all,
    does anyone have any recommendations (make, type) as to possibly adding fog lights to the tops of the crash bars. I have looked at the touratech ones but was wondering if anyone had tried some others.
    Plenty of fog up this way in Yorkshire.
    Nicko
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    Re: Fog Lights
    hi nicko,
    welcome , now have a look in the search facilty under "fog/extra/spot lights loads info etc
    Treadtrader's Avatar
    Treadtrader is offline White van man
    Jul 2007
    Warwickshire
    Re: Fog Lights
    Not really foglights but 55watt projector spots. Bought them off fleebay, £40 the pair.
    Wired independant of lights so i can run them with just sidelights.
    More so i can be seen and no glare from headlights in fog/mist.
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    Re: Fog Lights
    proxima1304's Avatar
    proxima1304 is offline Member
    Nov 2009
    Istanbul
    Re: Fog Lights
    http://i673.photobucket.com/albums/v...4/DSCN1023.jpg
    had one touratech side HELLA Micro DE 55 W.
    Added 2 more on the bottom for day light long rides for increased presence...
    Then swithched the first hella to an emergency beacon... it flips much like cop's (illegal in Turkey and possibly on the continent/USA) but here in Turkey we live on by the adage "I am invisible and everybody else are distilled idiots"...so if you survive the mortar holes (anybod in service?)in the middle of motorways (not highways they are cool nd of equal quality vis a vis Eur.) there is a good chance you are gonna run down by somebody who will claim she/he did not see you!
    Kerem Cesmebası
    GOG 007's Avatar
    GOG 007 is offline Senile member, who r u ?
    wing,leighton buzzard, beds
    Re: Fog Lights
    Quote Originally Posted by proxima1304 View Post
    Kerem Cesmebası
    Thats looks like a nice AT, you got anymore pictures anywhere ?
    [CENTER] [/CENTER]
    [URL="http://www.TickerFactory.com/"]
    [LEFT] [/LEFT]
    [/URL]
    Nov 2009
    Istanbul
    Re: Fog Lights
    here you go...awfull quality though...dust in the air and I am techno-ignorant! Will take more photos out in sunlight. fooling around with a vinyl sticker design ....XRV Turkish Twin L'Orient.... basically orientalizing the looks with the national colors and the star and crescend...
    basically what you see here is an R 1200 GS's D shaped upper fairing crash bar and the touratech's side pockets. Will take them off and let you observe the crash bar.
    I welded two steel threds where I was planning on mounting the 2 hellas but benchmarking from a machine with a central "front" suspension system with very limited fork movement...my Hellas were gonna be doomed when the forks closed by some 15 cms...so I laser-cut two steel "fins" carrying the spots from centerline to the sides...getting away from harmsway imposed by suspensions during harsh brakes...
    there you go...
    http://i673.photobucket.com/albums/v...4/DSCN1011.jpg
    http://i673.photobucket.com/albums/v...4/DSCN1007.jpg
    http://i673.photobucket.com/albums/v...4/DSCN1008.jpg
    Kerem Cesmebası
    Nov 2009
    Istanbul
    Re: Fog Lights
    Anybody have an idea how much electric using gear we can load on the system?
    Electric is not my favorite area of expertise.
    There has to be a logic to the total flow of energy produced by the alternator and the number of gear we can hook up on the system.
    For instance I have 2 x 55W spots + standard front lights+and a blinker (HELLA Micro).
    I am consdering adding a heat grip too...
    ideas...
    how far can we go? Will the wiring allow for alternating uses of the above or endure all at the same time...mainly the heat grips and the spots+standard front lights???
    Kerem Cesmebası
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Fog Lights
    Hi Nicko, your local Halfrauds stock Ring lights, you can get them complete with fuse, relay, cable and all the mounting bits you need with easy enough instructions
    I've got the mini fitted which are tiny with 55watt H3 bulbs although I have changed the bulbs for LED as an extra 110watt drainage was too much to use as running lights
    Sep 2007
    York
    Re: Fog Lights
    Thanks all for your pics and comments, going to pop down to Halfords in the next couple of days to take a look at their lights.....although I do like the shape of the projector lights. Could be a goer.
  1. Led lights
    By TRANSPORTER in forum Mechanical Advice
    Last Post: 28-10-09, 11:59 AM
  2. No lights
    By insainwayne in forum XR
    Last Post: 23-01-09, 05:09 PM
  3. Lights
    By Djo in forum Mechanical Advice
    Last Post: 02-12-07, 06:34 PM
  4. Lights, need more lights . .
    By Steve T in forum Transalp
    Last Post: 03-10-07, 03:44 PM
  5. No lights?!
    By Yeti in forum Transalp
    Last Post: 22-11-04, 12:00 AM
