Results 1 to 6 of 6
Thread: Fork Gaitor Clip
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Fork Gaitor Clip
    Does anyone know where I can get some thin clips similar to the original ones used to fix the fork gaitors? They“re a lot thinner than standard jubilee clips. Honda want around £8 each for them! Parts 27 & 28 in the pic below.
    Sully22252 is offline Senior Member
    Sep 2008
    Cornwall
    Re: Fork Gaitor Clip
    I've got a set of them spare, top and bottom, used but still good. Photo attached. They would need cleaning up and maybe a respray with some Hammerite smooth or something similar. If you want them pm me and I'm sure we can do something.
    Regards
    Chris
    SteveXRV's Avatar
    SteveXRV is offline Junior Member
    Sep 2009
    Oldham
    I had to cut mine off when having the fork inserts fitted and also couldn't source any locally that were thin enough. Oddly, after pulling the gators back into position they haven't moved and seem a very tight fit with no clips at all. I should really get some though!
    barftone's Avatar
    Apr 2005
    Bath, England
    Cable ties?
    Bolton, Lancs.
    Quote Originally Posted by barftone View Post
    Cable ties?
    Just what i was going to say, . . i use them on my trail bikes, never had a problem and if you want to check the legs are clean just snip the tie off and put a new one on when finished.
  1. Fork Gaitor Size
    By Knobblywobbly in forum Africa Twin
    Last Post: 10-03-10, 12:31 PM
  2. XR 400 gaitor options
    By kristian1ify in forum XR
    Last Post: 03-01-10, 04:51 PM
  3. Ryedale Movie clip
    By mikmac in forum Competitions / Trials
    Last Post: 29-09-07, 01:54 PM
  4. Just a clip i found on you tube
    Last Post: 21-08-07, 09:51 PM
  5. A clip for Lord Vader
    By anton88 in forum Chatter
    Last Post: 31-03-06, 10:58 AM
