Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Painting engine cases
    mhouck's Avatar
    mhouck is offline Member
    Jul 2010
    Rocky Mountains, Canada
    Re: Painting engine cases
    Quote Originally Posted by Wingnut View Post
    Futter
    Yes , my bike had a previous owner who knew nothing about bikes or just didnt give a sh1t . If your going to refurd your shocks you should change the oil seals and dust seals at a minimum and buy the way its easy.
    I striped my forks for a rebuild. Wire brush the housings of the fork , then filed down a couple of nicks , did a good job degreaseing them and sprayed em with hammerite silver smooth finish and gave them a week to cure in the house. This is what they looked like before I started.
    And this is how they finished up.
    I did the head stock and lower as well .
    I'm minding the bike now so far theres been no problem with the paint in fact the hammerite on the crank cases seems to have cured hard on account of the heat time will tell but Im happy.
    Hope thats of some help.
    Jonny
    Thats Nice Work on the shocks.
    Did you just use a wire brush for the headstock and lower as well?
    BTW, where did you get the fork boots? I've been looking, but have not had much luck.
    Wingnut's Avatar
    Wingnut is offline Senior Member
    Sep 2009
    Ireland
    Hey how are ya going.
    Yeah wire brush and paint is still on em. Boots from wemoto but have started to perish - junk.
    Jonny
  1. engine painting
    By sean in forum Mechanical Advice
    Last Post: 23-06-09, 01:11 PM
  2. XR600 engine cases help needed
    By ade6873 in forum XR
    Last Post: 18-02-09, 01:15 AM
  3. Engine painting. Advice needed.
    Last Post: 30-12-08, 09:05 PM
  4. Painting & engine question
    By Santiago in forum Africa Twin
    Last Post: 01-05-08, 12:00 PM
  5. Painting engine cases
    Last Post: 29-08-06, 11:16 PM
