Results 11 to 20 of 25
Thread: Vibration from pegs XRV750
    Highlander ji's Avatar
    Highlander ji is offline Junior Member
    Oct 2009
    Ireland
    Re: Vibration from pegs XRV750
    gooood man ANGELO !
    have joke 4 it on the way i hope thats the problem anyway i'll let u know if its gone or not. AL OF U! i cant walk without pains because of my ankle,but i have 2 find why its like that, anyway i will not stop 2 ride my RD07. LIFE IS 2 SHORT!!! i spend 1 year 2 find the answer and i didnt win.
    thx and god speed. henry.
    tserts's Avatar
    tserts is offline AfricAddict
    Mar 2010
    Athens
    Have you tried changing the rubber? Old and worn out rubber doesn't do the trick, I remember when I changed mine, mainly for "cosmetic" reasons, I saw a huge difference. They're pretty cheap so you could give it a go...
  4. #13
    Oct 2009
    Ireland
    u ment rubbers on the pegs
    i will try 2 get them and swap 4 fresh ones
    i have ordered CARBURETTOR VACUUM GAUGES 2 CYLINDER and we will see what will be next step ???
    THX.
  5. #14
    Oct 2009
    Ireland
    u r right ANGELO is hard 2 get there i think i will move tank 2 get better acces 2 it just have 2 wait few days till get that gauge,because i bought right one on ebay last night from england. we'll see after.
    thx.
  6. #15
    angelo's Avatar
    Apr 2006
    West Wales
    I note the comment about new rubbers but many of us and myself included have replace the pegs for all steel ones a bit wider and more grip I don't get significant vibration - a tingle at some speeds but most of the time it's fine.
    What kind of boots do you wear?
  7. #16
    Oct 2009
    Ireland
    Well thats right question i had POLO boots witch is german brand but by the time they were bad in wet than i bought DAYTONA also in germany cca 380 EUR. Those new r much better 4 vibrations but still if i do spin around 250 milles i feel it 4 week.
  8. #17
    angelo's Avatar
    Apr 2006
    West Wales
    OK I have Daytona Boots for my road bikes and they are very good BUT not as comfortable on the Africa Twin as the enduro type boots I have - these are Hein Gericke Touareg. Remember that I do not have rubber at all.
    How is your riding position? Are the pegs under the arches of your feet or on the ball of your foot? It is better on the ball of your foot.
    Does this happen at all speeds - is there a rev. range that vibrates more than others - maybe a change of sprocket to a higher gear might help - I have done this and so for road touring it does not rev so high.
  9. #18
    barftone's Avatar
    Apr 2005
    Bath, England
    I agree it's probably carb balance. When you get your new guages. Plug both one after the other into the same inlet to make sure they read the same. Some of the cheaper sets can be poor.
  10. #19
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    If it's between 4000-5000rpm, I'll bet it's a carb balance problem.
  11. #20
    Oct 2009
    Ireland
    well ANGELO it makes no deferent how u keep your feet on the pegs i have already tried that. but what i didnt mentioned i get also some vibs 2 right handlebar. only right side of the bike is affected from vibs witch is weird.
    BARFTONE thx 4 tip i will do what u sad 2 make sure i do not read bullsh... from gauges. again smth new.
    THX LADS 4 SUPPORT. henry.
    P.S.dont have joke yet.
  1. Odd vibration
    By evilhomer in forum Africa Twin
    Last Post: 15-03-09, 11:04 AM
  2. VIBRATION
    By shakawe in forum Africa Twin
    Last Post: 31-07-07, 03:48 PM
  3. that vibration
    By darthDassie in forum Africa Twin
    Last Post: 09-12-06, 07:57 PM
  4. vibration
    Last Post: 17-10-06, 12:53 PM
  5. Vibration
    By Simmo in forum Africa Twin
    Last Post: 27-06-06, 08:01 AM
