Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Vibration from pegs XRV750
    Highlander ji's Avatar
    Highlander ji is offline Junior Member
    Oct 2009
    Ireland
    Question Vibration from pegs XRV750
    Hi everybody!
    i have xrv750 02 year boght last april and i did good millage (12.000 milles) since that time but my right ankle is gone from vibrations from peg i know that the engine is mounted to the frame without any dumpers but there must be some solution how 2 make it smooth.
    CAN ANYBODY HELP PLEASE?
    thx.
    jamie92j's Avatar
    jamie92j is offline bike nut
    Aug 2008
    The 'Shire'
    Re: Vibration from pegs XRV750
    do you have the rubber bits on the pegs?? if not that can make a difference....
    everything is OK
    http://rt.com/
    Oct 2009
    Ireland
    yes i do
    before i had steel pegs 4 offroad but i took them very quickly down and fitted original rubber ones whitch was bit better
    its not even about tyres since ive got my bike i tried diferent brands and metzelers r the best.
    dont know what 2 do?
    jamie92j's Avatar
    Aug 2008
    The 'Shire'
    have you given the area around the pegs and all bolts attaching engine to frame a check to see if any our loose, as this can cause it. infact anything loose could cause excess vibs, so check everything is done up and not 'wobbley'.
    also check wheel, swingarm, head and linkage bearings...
    hope you can find the cause
    everything is OK
    http://rt.com/
    Oct 2009
    Ireland
    I'll see what i can do 4 it. Thx.
    Paul-S's Avatar
    Jul 2007
    Runcorn, Cheshire
    Have you had the carbs balanced and also are you using an aftermarket end can / exhaust?
    Oct 2009
    Ireland
    i had on the beginning original can but i replaced that 4 laser produro and no deferent
    never had done those carbs balanced is it big job 2 do it
    thx henry.
    angelo's Avatar
    Apr 2006
    West Wales
    Carbs - easy if you have tool to do it and know what you are doing - makes a huge difference
    Oct 2009
    Ireland
    i found some video on utube and was 4 gs1200 and doesnt looks like something so hard u can make a tool your self from plastic clear pipe with diometer5-6 mm some 2 stroke oil like indicator inside the tube stand few clips and here u go
    or i m wrong and there something what i should know before i tuch it???
    angelo's Avatar
    Apr 2006
    West Wales
    Yep you can make the tool but it needs to be consistent and accurate or you won't see the benefit. Make sure engine is hot preferably straight after a run. The adjuster screw is a pig to find and turn - easier with a right angled geared screwdriver
  1. Odd vibration
    By evilhomer in forum Africa Twin
    Last Post: 15-03-09, 11:04 AM
  2. VIBRATION
    By shakawe in forum Africa Twin
    Last Post: 31-07-07, 03:48 PM
  3. that vibration
    By darthDassie in forum Africa Twin
    Last Post: 09-12-06, 07:57 PM
  4. vibration
    Last Post: 17-10-06, 12:53 PM
  5. Vibration
    By Simmo in forum Africa Twin
    Last Post: 27-06-06, 08:01 AM
