Please help
I would like to increase seat height on my At RD07. Is there any easy way to do this
Thanks,
Vladimir
Please help
Thanks,
Vladimir
you could adjust the mono shock, its how i raised mine
putting the bike up on its belly pan so the back wheel is off the floor, you need to adjust the locking ring on the shock up and out of the way, then adjust the lower ring down. then put the locking ring back.
thats a very simplified version of what needs to be done, but it contains everything i did to mine.
im now about 1/2 inch of thread off the bottom of the adjustment.
edit - ive obviously interpreted your question as "how can i raise the ride height of my bike".... apologies if this isnt what you where after
Chris.
_____________________________
or just get a new seat foam made and recover it - therefore giving you a thicker seat...
TLD2008 15.41
I have a ticker seatand I have adjusted mono shock but it still looks low..
Hagon adjustable shock and ramp it up. I am on tip toe but can lower if I want to.
And the price? how high AT can be with this shock?
The basic shock with adjuster is about £350 bit they will tailor make one for not much more. I have never jacked mine up t full height because even with luggage and two up just a coupe of extra turns makes it fine (I like flat feet on the ground with that amount of weight on board)
Well,
I am leaving on trip around the world on May 30th and will have twp alu panniers and bag and tires.. Plus I am 195cm... I want to be high![]()
Hi,
80mm sounds superCan you tell me few things:
1. Do you think, is this somehow affecting riding (stability, etc..)
2. Is it easy to shorten that linkage? I cannot see on pictures, does that horizontal linkage exists also on the other side?
If I understood correctly, I would have to cut 8-10 mm and drill a new hole, right?
Thanks,
Vlada
