Results 1 to 5 of 5
Thread: Engine mounting brackets problem
    pshero is offline Junior Member
    Apr 2010
    Ireland
    I noticed the front two engine mounting brackets are decaying to dust on a 91 AT is this a common problem ,the two brackets under the radiators that is ....
    Apr 2010
    Ireland
    Re: Engine mounting brackets problem
    Anyone??
    futter's Avatar
    Jul 2005
    Suffolk
    Do you mean the alloominum ones? Typical issue for some and not others, mine are not too bad - 50181-MS8-000 and 50182-MS8-000 - call a Honda dealer - see how much they cost, probably not much, £20-£30 maybe?
    Apr 2010
    Ireland
    Yes Futter ,them alloominum ones ,you have answered perfik ,part numbers and all ,much appreciate your help .....thanks ...........
    futter's Avatar
    Jul 2005
    Suffolk
    No worries
  1. Engine problem
    By DAVID 61 in forum Dominator / FMX
    Last Post: 27-07-09, 08:46 AM
  2. Lower front engine mounting bolt
    By chalky4 in forum Transalp
    Last Post: 21-04-09, 02:26 AM
  3. Engine mounting bolt??????
    Last Post: 13-04-09, 08:18 AM
  4. Lowering Brackets
    By Bikertone7 in forum Africa Twin
    Last Post: 18-02-09, 05:10 PM
  5. Touratech Crashbars - Brackets etc
    By louis_holtz in forum Africa Twin
    Last Post: 11-01-09, 01:27 PM
