Results 1 to 10 of 31
Thread: Crash Bars
    beddowsm's Avatar
    beddowsm is offline it's about an hour......
    Mar 2010
    runcorn
    Crash Bars
    I know there has been several postings in the past regarding crash bars for the AT. Ive read most of them and done my own research but am no closer to deciding on what bars to get. I put a posting in the for sale and wanted asking for crash bars, but no joy in buying a second hand set...so Im going to buy new.
    I wanted something that protected as much of the fairing as possible which directed me to the SW Motech ones, engine bars + fairing protectors...cost £169 from wemoto. Only problem with these is the mounting. I wanted to stay away from anything that connected to the bash plate after reading all the previous engine bars postings. I can see that the bash plate is only connected with a couple of small bars. And in an accident I can see these snapping.
    So, looked at the other SW Motech ones, just the engine bars. They are mounted onto the central engine column but they dont protect as much of the fairing. Cost £141 from wemoto.
    Considered the Touratech ones, (think approx 170 euros, cant remember where from). Again, they mount better but dont protect much of the fairing.
    So what should I get??? It concerns me that my only reason for wanting engine bars is to protect as much of the bike as possible when I drop it. This includes fairing as well (I know the panels are not cheap). And if the lower engine bars dont do this then whats the point?
    Has anyone got the full fairing ones who has had an accident - does the mounting brackets snap? And anyone got the lower engine bars who has had an accident. Any damage to the top fairing panels?
    Any alternaives that satisfy my requirements? And for under £200.
    Whealie's Avatar
    Lewisham, SE London
    Re: Crash Bars
    SW Motech from Wemoto. An off at 50mph that FrancisGeoff measured afterwards had the bike scraping along its side for something like 35m left the bars worn half-way through but the fairing undamaged.
    Can't fault them.
    beddowsm's Avatar
    Mar 2010
    runcorn
    Re: Crash Bars
    Can't fault them.
    Which ones, the engine bars, or engine bars with fairing protectors? On another note - replaced my battery, replaced blown fuse for headlights. Tested reg rec (haynes manual instructions - finally got to understand it) and correct voltage flowing through. Checked voltage of battery when engine running and all are within normal tolerances. Thanks for the advice from previous posts Whealie.
    beddowsm's Avatar
    Mar 2010
    runcorn
    Re: Crash Bars
    Did more research on this site (and the web) on crash bars....decided to go with the SW Motech ones, but then found that www.motorbikesandparts.co.uk are flogging Givi bars for £71.16 including postage. So went for the cheaper Givi bars.......Time will tell if I have made the right decision, but they are half the price of the sw-motech bars and I have other things I want to buy for the bike, so cheap wins for now.
    Axe
    Axe is offline Senior Member
    Oct 2009
    Manchester
    Re: Crash Bars
    I'v just ordered some givi bars for my strom from
    I found them after a google search and they certainly seem very cheap compared to everywhere else.
    Found some reviews about them on the vsrom owners club site.
    apparently delivery can be very slow, so if you aren't in a rush!!
    V-strom.co.uk members also get a 10% discount (but you can't use it at the same time as the free postage)
    I'm considering the Alpos Aluminium cases, 2x41Ltr ally boxes for less than £200. Bargain!
    (Imagine all the hair straighteners I could get in them!!)
    Axe
    Kjell Lindberg's Avatar
    Sweden
    Re: Crash Bars
    Quote Originally Posted by beddowsm View Post
    http://www.touratech.com/shops/001/i...37KFNd_F5AMhaQ
    Or you could have a look at these:
    Tanksturzbügel Pro II schwarz
    Tanksturzbügel Pro II weiss, Fence Version
    http://www.africanqueens.de/html/hon...turzbugel.html
    Cookie is offline Toolbox
    Feb 2010
    Nieder-Olm, Germany
    Re: Crash Bars
    If you can afford it, get the Touratech set. Mounting of SWM bars is a bit of a bitch and many of us in Germany (me too) using them have modified the holders around the frame to avoid contact with brake lines or to avoid using the upper mountings of the cooling units, which are stupid to use to begin with. Check out www.africatwin.de : Beitrag anzeigen - SW-Motech Sturzbügel & Kühlerbefestigung bei 07/07a at the German AT forum, you´ll see some pic of modified upper mountings, including some from me (Keks).
    Whilst the SWM have a good crash record, the TT´s have as well.
    I´ll strip the bike and repaint the frame next winter and at that occasion will buy myself some TT bars for Christmas.
    Chris
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Re: Crash Bars
    Does anyone know if these carsh bars, for the RD07, will fit the RD04? If not, could they be modified simply to fit?
    mjk's Avatar
    mjk
    mjk is offline were did all my hair go?
    Jan 2010
    HEREFORDSHIRE UK
    Re: Crash Bars
    I just got some SW Motec bars from www.wemoto.com for my RD07. For the white ones its like £130 something and for the black ones its £140. Took 3 days before it was deliverd to me and took me about 20min to fit them. have a look on wemoto`s website you will find loads more goodies for your bike. Only problem is the instructions are mostly in german but there are pics to so its easy even for blokes like me
    RD07a 1999 AT , The Blue Bullet
    mjk's Avatar
    mjk
    Jan 2010
    HEREFORDSHIRE UK
    Re: Crash Bars
    Quote Originally Posted by Knobblywobbly View Post
    Knobbly , just go to wemoto`s website and specify what your bike is , RD07 or 04 and it will come up with the bars you will need
  1. Wanted: Engine bars / Crash bars
    By DrSmith in forum For Sale / Wanted
    Last Post: 04-02-10, 06:23 PM
  2. More crash-bars....
    Last Post: 05-01-08, 07:18 PM
  3. Crash Bars & pannier bars on a TA with a Remus ??
    By mightdomaybe in forum Transalp
    Last Post: 10-04-07, 06:37 PM
  4. CRASH BARS
    By simon0bikes in forum Africa Twin
    Last Post: 19-10-06, 11:49 AM
  5. Crash bars for 04-07
    Last Post: 19-04-06, 10:06 AM
