Results 1 to 9 of 9
Thread: XRV 650 Brake slide pin caps
    dietbrand is offline Junior Member
    Oct 2008
    Belgium
    Hi everybody!
    Has anyona got any tips on removing the slide pin caps that seal of the brake pins in the front caliper of the RD03?
    I've got to rebuild the caliper and got is of the bike but can't for the life of me get the two screws out to get to the actual pins. I'm letting it soak in deblock oil for the night now, but any tips are more than welcome.
    Cheers,
    DbVdb
    futter's Avatar
    Jul 2005
    Suffolk
    Re: XRV 650 Brake slide pin caps
    I always remove them (on my RD04) whilst on the fork leg. It makes it easier as you can get better purchase on the screwdriver. You can also (as a last resort) use an impact driver, but make sure the fork bolts are tight. After that you need to hammer/drift them out!
    Cookie is offline Toolbox
    Feb 2010
    Nieder-Olm, Germany
    Quote Originally Posted by dietbrand View Post
    Hi everybody!
    You´re talking about a screw similar to #18 on that picture? Motorrad Teile f�r Honda XRV-750-T (G) / F-9 VORDERRAD-BREMSSATTEL
    These are a bitch. I recently ended up drilling one out, which can only be done once the brake is on your workbench. I´ve been able to drill through and leave only a thing ring of the screw, then stick an allen key through the hole and screw out the main bolt underneath, which then, once meeting the drilled-through screw, turned the screw out as well. The better way is probably to drill a smaller hole and use a screw extractor (a conical screw, cutting it´s own thread by turning left instead of right). Impact wrenches are said to work as well, but I would be hesitant to use those on the break.
    Regards
    Chris
    Bolton, Lancs.
    Impact wrench/driver.
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    An impact driver or a big screwdriver with a square or hex shaft that you can put a spanner or grips on.
    Remount the caliper on the fork leg to give you improved leverage.
    Use plenty of Copaslip (copper grease) on reassembly and you shouldn't have the problem next time.
    Good Luck
    Oct 2008
    Belgium
    Thanks for the info guys, I got them off (eventually) with an impact wrench.
    But I can't seem to get a break with this brake.
    Underneath the caps the previous owner left me a nice little surprise in the form of completely stripped heads
    The only way I see getting them out is to use a screw extracter with a reverse thread. I haven't got the tools or experience to do this (don't want to mess up the caliper learning how to do it properly), so I'm now making this my mechanics problem
    As always thanks for the help!
    fridge Guest
    Had the same problem myself and the mechanic just gently hammered in tightly fitting a torx bit, into the mashed allen hole, and then undid the pin. You'll need a new pin if it works but it was remarkably easy. I'd spent ages filing down an oversize allen key which didn't work at all, a torx bit should grip a lot better.
    Feb 2010
    Nieder-Olm, Germany
    Actually, this is usually the easier-to-solve problem. Cut the pin, remove the brake pads and turn the remaining pin with a good grip.
    Chris
    Quote Originally Posted by Cookie View Post
    Chris
    That would be my solution as well.
    I am sure David Silvers could supply the replacements.
  1. Carb slide holes - which diameter
    By Chris.R. in forum Africa Twin
    Last Post: 03-09-09, 07:27 PM
  2. 35mm Slide Scanners - Photography
    By kitped in forum Chatter
    Last Post: 03-03-09, 05:00 PM
  3. Jenna/Kymmy..slide catch
    Last Post: 12-09-07, 03:59 PM
