Results 11 to 20 of 23
Thread: Service -Valve Clearances
    raymo's Avatar
    aberdeenshire Scotland
    Re: Service -Valve Clearances
    mm I would check the carbs..
    LWR did his on the Alp nd it was a mile out.. said they looked as if they had not been touched from new... made a difference too....
    XRV 650R RD03 1989
    The Longest Day Rider 6
    cbrpaddy Guest
    Just bend the feeler gauges, it's what I did. Works too.
    Outrageous, mine come in a nice, er, holder thing, they wouldn't be able to fit back in Actually though, I got another set for a fiver in Halfords which I'm going to mangle instead.
  4. #13
    foz1969's Avatar
    Jun 2009
    the words "valve clearance check" concerned a "2 stroke" guy like myself... needn't have worried. Easy peasey, get on with it & put it back together (after ajusting nothing most likely) then go for a well earned blast. would say good luck..... but you won't need it.
  5. #14
    Lutin's Avatar
    Galway
    Quote Originally Posted by cbrpaddy View Post
    Don't feel like "adjusting" (bending) your own feeler gauges? Then why not try these pre-formed feeler gauges from Draper? All for £5.58 apparently.
  6. #15
    Mutley's Avatar
    May 2004
    Top of the hill
    You've gotta make the time to do the tappets while you're servicing the bike, once you've done them & realise it's not too bad, you'll be laughing
    Balancing the carbs is quite simple once you've done them once or twice and will easily make a difference to how smooth the bike runs. They're easier on the RD04 than the RD07. I've got a cheap ratchet screwdriver that works at an angle that IS really cheap n nasty but makes the job on the RD07 simple
  7. #16
    Waynes World is offline Member
    Beverley, East Yorks
    I was in the garage doing mine last night for the first time, following the book. Started with the rear pot, they were way out, bit of adjustment on all three... then realised the exhaust valve was the one at the back and I'd just set the gaps farse about ace, ...d'OH! (I'm used to exhausts coming out the front of engines - schoolboy mistake with a V twin!).
    I was in there until one in the morning anyway....
  8. #17
    olionel's Avatar
    olionel is offline Very Enthusiastic Member
    Sep 2010
    Manchester
    to do the valves do I need to take any radiators off ? RD07
    if so does this mean draining the whole of the cooling system??
    Oliver
  9. #18
    Quote Originally Posted by olionel View Post
    Oliver
    No, unbolt the guard (there is a hidden 3rd bolt I think) then unbolt the radiator. Leave all hoses connected, this gives enough play to move it enough to get to everything.
  10. #19
    piguglyshandydrinker's Avatar
    East Lancs....
    Mike, it IS worth checking the valves & balancing the carbs.
    If you want a hand or to use some carb balancers, give me a bell.
  11. #20
    beddowsm's Avatar
    beddowsm is offline it's about an hour......
    Mar 2010
    runcorn
    Thanks Phil, I may take you up on this at some point in the future. You probably guessed that I skipped these jobs. I have a habit of breaking things when stripping the bike so its probably best I leave this alone for now. Its running, and doing well at the minute. Maybe a job for the winter days......
  1. Valve clearances
    Last Post: 18-06-11, 09:23 PM
  2. TA 600 Valve clearances
    By Warthog in forum Transalp
    Last Post: 09-12-09, 08:29 AM
  3. SLR 650 Valve clearances ?
    By pelt in forum Dominator / FMX
    Last Post: 03-11-07, 01:55 AM
  4. Valve clearances.
    By Chris J Barrett in forum Africa Twin
    Last Post: 14-06-05, 12:57 PM
  5. Big service questions - valve clearances ?
    Last Post: 23-08-04, 08:34 PM
