Results 11 to 20 of 21
Thread: 123 miles on a tank!! and awfull run on reserve
    begazzz's Avatar
    begazzz is offline Member
    Jun 2010
    ilfracombe
    Re: 123 miles on a tank!! and awfull run on reserve
    thanks all for the above...
    air filter new as are the plugs
    going to rotate the fuel filter and avs me a look at the choke.
    might leave the tank for a bit as just filled up...still if i dont sort it it wont be full for long.....
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    I'd absolutely suspect the chokes in the first instance.
    You need to check the complete assembly, from the lever, down the cable to the splitter, then two cables to each carb. Then check the plungers and the springs in each carb. Usual warning, DO NOT break the plastic nuts holding the chokes in the carb, otherwise you'll be buying an expensive new assembly!
    After you've fixed it, you have to remember that the AT engine is an old design, so not the most economical thing. Saying that, 200 miles from a tank should easily be achieveable and if you ride smooth you'll get maybe 20 or 30 more than that.
    Thrashing away from the lights, revving the tits off it, or staying at 80mph plus on an AT and you will see your MPG plummit.
    Good Luck
  4. #13
    VENNIC's Avatar
    VENNIC is offline Junior Member
    Jun 2010
    South Africa
    I say it’s the chock
    I only got 90 miles on a full tank….. and on 110 miles it kept on blowing spark plugs.
    The choke is a big problem, and even a new one doesn’t last long….. and then get stuck again.
    I can’t do without it, it’s too cold in the mornings.
  5. #14
    begazzz's Avatar
    Jun 2010
    ilfracombe
    chokey dokey!!
    Had the choke appart and blasted some 3 in 1 oil down untill it dripped out of the carb ends on both sides.....didnt seem stuck but at least its done and the action is a bit smoother.
    easy to get to isnt it!!!!!
    checked all the breather hoses and they are fine..
    going to check the flow from the tap on reserve to see if its a bit blocked now..........after ive had an oily cigarette
  6. #15
    begazzz's Avatar
    Jun 2010
    ilfracombe
    ok checked the tank and the tap chucks a load of fuel out with the tap in the "ON" and "RES" position. so i guess ill just run the tank down and see if:
    A: fiddling with the chokes improves mpg
    B: fiddling with everything else helps running on reserve
    thanks for you asistance fellow twinners
  7. #16
    darthDassie is offline Member
    Nov 2006
    Cape Town, South Africa
    Agree with the choke plungers idea - I removed mine a few years ago - blanked them off completely and really improved fuel consumption. Would look at that.
  8. #17
    Magnum PI is offline hondabore
    Jan 2008
    devon
    I removed mine a few years back and since then i get between 210 and240 miles from full to to the start of reserve thats town riding i get a lot more on a good run
  9. #18
    begazzz's Avatar
    Jun 2010
    ilfracombe
    So if i were to blank of my chokes how have you done it and how would you get it started on a cold morning??
    if were to blank off i guess i would take the plunger off and put them in the hole and put a bit of silicone over to blank them off...??
  10. #19
    When bike is warm put a cover over the engine, it should help with starting the next morning.
  11. #20
    Bolton, Lancs.
    Quote Originally Posted by begazzz View Post
    Remove choke assembley,
    take plunger and spring off cable,
    replace plunger and spring and hold in place with a 'pad pin blanking screw' from the front brake caliper's. (I got new ones from honda dealer for a couple of quid each.)
    Do this with both carb's.
    It can be a bit tricky to start in very cold weather.
    I used a stronger shorter spring so its easier to get the blanking screw in position.
    Keep the plastic bits safe incase you want to put chokes back in winter.
    you can fit stronger springs to cables (if you can find some).
    Spark plugs will probably be black so worth changing while you have tank off.
  1. Miles per Tank
    By russt1969 in forum Africa Twin
    Last Post: 11-12-08, 11:30 AM
  2. Screw size for the plastic reserve tank selector
    By Devilkin in forum Africa Twin
    Last Post: 17-09-08, 09:58 AM
  3. Xr Miles Per Tank?
    By endurojoe1985 in forum XR
    Last Post: 16-02-08, 06:12 PM
  4. How many miles to reserve
    Last Post: 01-09-05, 01:01 PM
  5. Fuel Tank Reserve
    By miggy in forum Africa Twin
    Last Post: 29-03-05, 11:43 AM
