Results 11 to 20 of 23
Thread: Question for RD04 Hepco Becker owners (Whealie?)
    Whealie's Avatar
    Lewisham, SE London
    Re: Question for RD04 Hepco Becker owners (Whealie?)
    Just a quick bump to see if anyone else who might not have seen this had any advice about the strength of these welds vs the unwelded pipe before I fit them and risk it with heavy boxes.
    Still not sure if I should be sending these back and asking for them to be changed.
    Did you ever get a chance to have a look at your bike whealie?
    I don't need photos, but it'd set my mind at rest to know that I'm not alone and other hepco becker racks are like this (particularly ones that have been ridden offroad like yours).
    Sorry Zen, got overtaken by events with my nephew dying.
    Hope to get out to the garage tonight so will take photos.
    Zenarchy's Avatar
    North East UK
    I'm really sorry to hear about that mate. If I'd known I wouldn't have been bothering you (sorry about that). Seriously don't worry about photos of the bars - I can see you've got far more important things to be concerned with than a stupid weld on a bit of tube at the moment.
    Hope you're OK and your family coping OK.
  4. #13
    Zenarchy's Avatar
    North East UK
    I think they will all be manufactured the same.
    the tube on the other side is joined below the gusset.
    wherever there is a weld there is potentially a weak point, due to heat affected zones etc. this is lessened by various heat treatment/annealing processes for critical applications.
    if they had carefully ground the weld off it would be barely noticeable but would be weaker.
    Bottom line; . . . its not how i would have done it, . . . . but i can't see it being a problem.
    if your still concerned contact the supplier/manufacturer.
    Thanks for your help . I dropped hepco becker a line and they say it's because there's an inner tube to strengthen the tube in that place and the weld there is to stop it rattling around inside. Seems a bit odd when there isn't a weld in that place on the other side, but I think I'll fit them and see how they go. I'm probably worrying over nothing by the sounds of it.
  5. #14
    Farmboy's Avatar
    Farmboy is offline Senior Member
    May 2008
    In My Own World
    just checked mine and there is no weld there.
    Cant imagine it being an issue though, If your ever in the situation where they break the chances are the last thing on your mind at the time will be your weld line
  6. #15
    Zenarchy's Avatar
    North East UK
    Thanks mate. I was thinking it was a load of balls that it was a design feature (couldn't see it on any of the photos of them myself online either - unless it's something new they've started doing but I haven't read any reports of people saying there's tube rattling around inside so can't think why they've needed to start that).
    I'm gonna keep them and hope for the best anyway (assuming they actually fit OK - still haven't got around to that yet as work keeps getting in the way). All the rest of the mounting hardware seems really sturdy (probably more than it needs to be) so hopefully that'll prevent any problems if I drop it or with vibration etc.
    Are you back home already? Did you come back early, or has the time just flown by that quickly (if it has it's frightening! - I feel my summer slipping away from me )
  7. #16
    Farmboy's Avatar
    May 2008
    In My Own World
    back a bit early due to the bike turning into one cylinder a long way from home,
    It made it back though as did I so everythings good
  8. #17
    Jacqueslemac's Avatar
    Jacqueslemac is offline Top Cat
    Norfolk and Normandy
    Not close ups, but do they help?:
    1990 Africa Twin RD04
    2003 Triumph Tiger 955i
    "Do not indulge in dreams of having what you lack, but reckon up the blessings you do possess. Then reflect with gratitude how you would crave them if they were not yours." Marcus Aurelius
  9. #18
    Zenarchy's Avatar
    North East UK
    Quote Originally Posted by Farmboy View Post
    Ah..man..Sorry to hear you had to cut your trip short. At least you got back OK. Hope the bike's OK and it's nothing too serious.
    I'll be keeping an eye out for your ride report
  10. #19
    Zenarchy's Avatar
    North East UK
    Quote Originally Posted by Jacqueslemac View Post
    Thanks Jaques. They're the propper honda bars so are slightly different from the stock hepco beckers (your bars seem better to me infact in a few areas - in an ideal world I would have got some exactly like yours but they seem very rare and I gave up looking). They don't seem to be welded where mine are either (though as I say, they're slightly different in other ways too so this might be to be expected).
    Those photos might be really handy when it comes to fitting mine however as the mounting points etc. look the same and the design is still quite close
  11. #20
    I bought mine secondhand from eBay in Germany (thanks to a tip off from one of our Germany-based friends) a couple of years ago, so don't know how old they are.
    Here's a few more photos in no particular order:
    And one more of the finished article (you might be able to make out Stonehenge in the background):
  1. Hepco & Becker RD04 Pannier Racks fitted
    By Farmboy in forum Africa Twin
    Last Post: 02-10-11, 08:00 AM
  2. Wanted: RD04 hepco becker luggage rack
    By Zenarchy in forum For Sale / Wanted
    Last Post: 23-06-10, 08:42 AM
  3. AT RD04 Hepco & Becker Pannier Racks
    By BobA in forum Africa Twin
    Last Post: 26-12-08, 06:53 PM
  4. Hepco & Becker RD04 Pannier Racks Question
    Last Post: 14-12-08, 07:17 PM
  5. Fitting a Hepco & Becker rack from an RD04 to an RD07?
    Last Post: 25-08-06, 12:29 PM
