Results 1 to 10 of 13
Thread: Bike left at home - battery dies
    wink's Avatar
    wink is offline Junior Member
    Leeds
    I work away quite a bit, so have to leave the bike in the grudge for about a month at a time. Unless i leave it on a trickle charger, the battery will be dead flat when i get back. is this normal? or am i the only one who has to leave his bike alone for a month stretch??
    AckAckFlack's Avatar
    AckAckFlack is offline Truffle shuffle king
    Oct 2009
    Barnsley South Yorkshire
    Re: Bike left at home - battery dies
    Quote Originally Posted by wink View Post
    Change jobs - you are not doing yourself any good by not riding for a month at a time
    Actually better still keep the job going, you only live 30 miles or so away, let me look after the bike while you are away I am sure I will beable to keep it topped up for you.
    0-0¬
    Best performance modification to a motorcycle is to improve the skills of it's rider!!! - long way to go then!
    07 Honda Varadero in black- Named BIG MAMMA
    98 Honda xl1000 Varadero - Named OX- THE BIG DIRT TOURER
    02 XRV 750 - Red White n Blue - Wonderwoman
    raymo's Avatar
    aberdeenshire Scotland
    battery shagged or draining never had this prob when I worked away
    try leaving it discconected or get a new one
    leaving it trickle charging for 4 weeks '' fire hazard "
    XRV 650R RD03 1989
    The Longest Day Rider 6
    Bolton, Lancs.
    A month should be no problem, . . . unless you have an alarm on it.
    Only time i had a problem, . . . it was fixed with a new battery.
    serifrat's Avatar
    serifrat is offline Member
    Jun 2010
    london
    have u got heated grips? or any after market gadgetry attatched to ur bike? if so dissconect them and see if that makes a diffrence had the same problem on my fireblade.... heated grips
    lootch67's Avatar
    South Ockendon, Essex
    There's nothing abnormal about a battery loosing it's charge if the bike is used as little as yours. Stick with the trickle charger but consider putting it on a timer - an hour a day should be more than enough to keep the battery topped up.
    wink's Avatar
    Leeds
    yeah, lootch, that's the one. will do. cheers.
    angelo's Avatar
    Apr 2006
    West Wales
    Souds like your battery is on it's last legs - symptoms are as described - get a new one - I had the same in the end it was down at the end of the week!
    Axe
    Axe is offline Senior Member
    Oct 2009
    Manchester
    Have you got a sat nav on it?
    My Garmin mount had corrosion on the copper contacts (green fuzz) which was shorting out just enough to cause the same symptoms.
    a quick rub with the edge of a key between the contacts cleaned them up just enough to solve the problem.
    Axe.
    TLD 2008: JOG-LE 13Hrs 15Mins (Ish) 861.9 Miles
    TLD 2010: Lowestoft-Dingle 15Hrs 3Mins 602.2Miles
    On The Safe House List........
    wink's Avatar
    Leeds
    As far as Angleo goes, yeah, I've been watching the battery a while, but it's no problem if i'm at home ie it gets used everyday.
    As for the sat nav, axe, no, not now. there was one on but i'm a map man meself, so took it off - I like getting lost at times, seem to end up in more trouble that way . . .
  1. Wanted: Front caliper. Left side (sitting on the bike)
    By Warthog in forum For Sale / Wanted
    Last Post: 03-06-10, 10:22 PM
  2. Replies: 15
    Last Post: 14-07-09, 08:59 PM
  3. Monday 6th July - My bike should be home !
    Last Post: 02-07-09, 12:54 AM
  4. New bike's home!
    By africajim in forum Varadero
    Last Post: 15-03-09, 05:05 PM
