Results 1 to 9 of 9
Thread: Help Please - Crash Bars - Mounting Bolts
    African Simba is offline Senior Member
    NW - UK
    Just got round to fitting what I think a Ricky Cross Crash bars (Had them a while in my garage) to my Project Simba (RD07A), The engine mounting bolt (M10 X 250mm) is too short for the crash bars. Should there be a longer bolt with spacing collars with these bars? I can mount one half (LHS- gear lever side) no problem, but the other side (RHS) I am struggling with. The bar is about 4 cm out from the Bolt which means a longer bolt is needed. So my question is to people who experienced this before, which I think the case, A longer bolt is a must + collar spacer of some kind and would these come as std with the bars??
    Any idea if I can source one out from somewhere or have it custom made?
    Mutley's Avatar
    May 2004
    Top of the hill
    Re: Help Please - Crash Bars - Mounting Bolts
    Hi mate, All I can think of whilst trying to understand what you are looking at is perhaps the bars aren't for the 7A. There is a width difference between Africa crash bars for the RD04s and RD07s. At least that is what I discovered a while ago with an older RD07 I had, I bought some cheap bars knowing they were for the RD04. I had to get a mate to push the bars in to the frame whilst I put the bolt in as the bars were wider than the frame.
    If you do get a longer bolt with a spacer inside the bars, would this not hinder tour leg whilst on the bike?
    NW - UK
    Hi Mutley..You could be right here.. I have asked myself same question but yet the SW bars I have on my other bike came with a longer Bolt in the kit. At the moment the bars are touching the exhaust header and not lining proper with the bolt, At least a gap of 3 to 4cm is need with a collar in between.. I will take some photos tomorrow this will explain my dilemma..
    Whealie's Avatar
    Lewisham, SE London
    I suspect I have an unused SW Motech longer bolt for the RD04. Do you want me to measure it?
    beddowsm's Avatar
    beddowsm is offline it's about an hour......
    Mar 2010
    runcorn
    Hope you get the bars sorted before this Saturday! Although the terrain we are covering isnt too extreme there is potential to drop the bike. I have dropped mine on several occasions, mostly in daft scenarios...like whilst parking the bike on a down slope then going to open a gate only to hear the bike falling behind me....and a few sliding on wet grass on slopes....but all low speed.
    If it turns out the bars are not for your bike heres a cheap alternative - only question is would they arrive in time for this weekend. When I ordered mine they arrived in 2 days (I think). They take a couple of hours to fit...or did for me.
    HONDA AFRICA TWIN 95-98 BLACK Givi ENGINE GUARD - £71.16 - Motorbikes and Parts - Givi / Kappa Motorcycle Luggage Specialists - honda-africa-twin-9598-black-givi-engine-guard-p-18238.html
    GIVI bars, £71.16 inc postage, says takes 2-5 days via DHL. They are the ones that attach near the footpegs and Ive heard bad reports about them trapping the leg if the bike goes down...but so far they have been good for me. When dropped they bend (meaning you have to bend them back into shape) but have saved my fairing on a few occasions....and for £71.16 I think they are a great buy.
    NW - UK
    Yes please if that no Trouble to you... Just need to compare to std one which is 260mm Overall length..
    NW - UK
    Quote Originally Posted by beddowsm View Post
    Thanks Mate for the heads up and advise on the Givi bars. I have SW Motech fitted to my Other @ in which I will strip down and use on this one (This one is ready for off Road ride hence the swap)
    I'm still hoping to sort the Ricky Cross bars at some point soon..
    Looking Forward to Satrurday and "Not" dropping my bike
    Whealie's Avatar
    Lewisham, SE London
    Quote Originally Posted by African Simba View Post
    These are 260 too (from inside the bolt head to the end of the thread)
    NW - UK
    Thank you Whealie,, This sounds about right for the SW bars.. with the Bars I have now I need a much longer bolt. . Afterall, I think the bars I have may be for an RD04 as Mutley thinks..
    Many thanks again
  1. Help!! Mounting spots on crash bars
    By RickSkye in forum Mechanical Advice
    Last Post: 12-02-10, 03:57 PM
  2. crash bars advice: bolts needed...
    By Yahoo in forum Transalp
    Last Post: 30-05-09, 11:30 PM
  3. brake caliper mounting bolts
    By bazd in forum Africa Twin
    Last Post: 23-01-09, 02:09 PM
  4. Replies: 5
    Last Post: 09-11-08, 09:07 AM
  5. Crash bars - best type mounting wise?
    Last Post: 20-10-07, 10:48 AM
