Right then.. Time to install the Facet pump.
Could you guys help me in:
-The power outlet to the original fuel pump is the one on the picture.
Is it???
Is it???
That's the jobbie. Graft the old plug from your failed pump onto the Facet and Bob's your auntie.
OK, thanks!
I guessed it should be that one as it's the only one not connected. I'm uppgrading from a vaccumpump to a Facet.
I guess you haven't got a standard connector then. I think these may be the ones...
110 Connectors
Thanks Alan,
But I had already cut off the connector soldered new wires when you showed me the connectors yesterday.
Anyway, All done with the Facet istallation.
Works fine.
