Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Heidenau K60 Tyre Pressures?
    Re: Heidenau K60 Tyre Pressures?
    I found that increasing the pressure by one or two PSI can sometimes help.
    It is also a cheaper way of curing the fault.
    Whealie's Avatar
    Lewisham, SE London
    I fancy trying these next tyre change. Do you buy them a and fit them yourself? If so where from?
  4. #13
    beddowsm's Avatar
    beddowsm is offline it's about an hour......
    Mar 2010
    runcorn
    Bought mine from
    www.mytyres.co.uk
    Total for both K60s tyres = £122.40....
    Took them to a local bike shop to be fitted for a tenner a wheel. Wheels off bike.
  5. #14
    Whealie's Avatar
    Lewisham, SE London
    Quote Originally Posted by beddowsm View Post
    Bought mine from
    www.mytyres.co.uk
    Hmmn! just had a TKC rear and new tube supplied and fitted on a lose wheel for a ton (plus my wife took it there and back by taxi).
    Will buy a set of these and see how I get on. Will fit them myself
  6. #15
    beddowsm's Avatar
    Mar 2010
    runcorn
    Yep, I got quoted about £104 for a TKC rear, hence the reason for going for the K60's. Great tyre in my opinion. Cant fault them on road or off - although havent been through any real muddy bits off road yet, but they have loads of grip so I expect them to handle pretty similar to the TKC.
  7. #16
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Well mine have gone! Had a new Conti Escape fitted on the rear & my old Escape back on the front. The transformation is amazing - on the wet run home from the tyre place I aimed for every pothole, rut, groove and area of overbanding and the bike was solid as a rock
    Good riddance Heidenau
  8. #17
    trophydave's Avatar
    trophydave is offline Senior Member
    Feb 2007
    Nottingham
    Yes but what have you done with the old tyres
    Rust never sleeps
  9. #18
    Aug 2008
    Bognor Regis
    Quote Originally Posted by trophydave View Post
    Well I was going to put one around my dart board and use the other as a planter. But with a bit of luck I may be swapping them with another member for some more Conti Escapes
  1. Heidenau tyre, any good?
    By thetimkirby in forum Africa Twin
    Last Post: 07-08-09, 10:48 AM
  2. Tyre Pressures (Again!)
    By wade90 in forum Transalp
    Last Post: 02-05-09, 11:30 AM
  3. Tyre pressures
    By sparklymarkly in forum Transalp
    Last Post: 31-07-07, 06:15 PM
  4. Tyre Pressures.
    By peterb in forum Chatter
    Last Post: 10-10-06, 10:29 PM
  5. Tyre pressures
    By Dee Duble Yuh in forum Varadero
    Last Post: 25-08-06, 09:59 PM
