Results 1 to 5 of 5
Thread: Rear hub mashed by bearing failure
    stusmog is offline Junior Member
    Hampshire
    Angry Rear hub mashed by bearing failure
    Hi folks, my rear o/s wheel bearing went recently with no warning (and I do check them!), and managed to seize and spin in the hub. The bearing stops in the hub have been partly worn down, resulting in side pressure from the spacer with new bearings in. Also, I'm not convinced the bearings seat completely flat either! To add to this, there is wear on the sprocket carrier side, and it looks like the n/s wheel bearing doesn't contact the sprocket spacer until everything's done up.
    Does anyone know of:
    a: a rear wheel for sale, or
    b: somewhere that could fix the hub, that won't require a second mortgage!
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Rear hub mashed by bearing failure
    Stu
    You're subscribed matey, so why not make full use of the forum and place a Wanted ad in the WANTED/FOR SALE area HERE and you might be lucky!?
    Good Luck
    Hampshire
    Cheers for that, have posted an ad,
    Ta Stu
    futter's Avatar
    Jul 2005
    Suffolk
    Why not take it to a local engineer, get it machined to take a larger bearing with same width and ID?? Not goona cost alot.
    Hampshire
    That's worth a thought, only problem is there's no original surface left to work from, unless anyone's got a wheel off and can measure the distance the original bearing should sit at each side, then this can just be increased to take the wider one?
  1. rear wheel bearing
    By warriorkilt in forum Africa Twin
    Last Post: 18-08-10, 08:18 AM
  2. Replies: 4
    Last Post: 07-06-10, 09:32 PM
  3. Rear wheel bearing failure
    By Alba in forum Transalp
    Last Post: 10-04-09, 08:47 PM
  4. Rear wheels bearing life??
    By phil w in forum XR
    Last Post: 28-03-09, 01:56 PM
  5. Rd07 rear wheel failure
    By dmt4214 in forum Africa Twin
    Last Post: 11-11-08, 10:42 AM
