Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Xenon on RD07!
    jager's Avatar
    jager is offline Junior Member
    Aug 2010
    Subotica, Serbia
    Re: Xenon on RD07!
    I see a lot of bikes here in Serbia with both lights on. Nobody makes no problems with that, so why not to have them wired to work both? It looks better and it gives much better light
    ian porter's Avatar
    ian porter is online now May Contain Nuts
    Jan 2010
    Derby, United Kingdom
    Re: Xenon on RD07!
    Quote Originally Posted by jager View Post
    Well, there was one problem, but it vanished after locating the ballasts as seen on the pictures. The ballasts was placed on top of each other, and they were closer to the tripmaster. Not every time, but very often, at the moment of turning on the lights, the tripmaster reseted itself. Rarely it hanged, so a reset was needed.
    you can get a similar problem with the BMW 1150GS where the info display fails if you put the ballasts too close and it needs resetting periodically.
    obviously a common problem with HID ballasts in close proximity to electronic displays etc.
  4. #13
    antti's Avatar
    antti is offline Senior Member
    Aug 2008
    Southern Finland
    Re: Xenon on RD07!
    Jager, did You use this kind of BI set with moving parts?
    Any recommends for good set?
    G/S project bike.
  5. #14
    antti's Avatar
    Aug 2008
    Southern Finland
    Re: Xenon on RD07!
    I finally got hid kit assemled.
    I did use a H4-3 set. But how ever placement of burning chambers didn`t mach with H4 halogen and fitment was very poor.
    So i took whole moving system away and did glue another to mach with low beam and other one with high beam.
    I have two relays feeding power to ballasts and ballast are located under right hand side panel. It needed one metre exctence to bulbs wires.
    Original loom is used only for control.
    High beam bulb.
    And low beam. I did modify cover, it had a hole for high beam.
    G/S project bike.
  1. No xenon bulbs in your TA, sir...
    By Warthog in forum Mechanical Advice
    Last Post: 11-12-09, 07:55 PM
  2. Xenon in XRV
    By twin in forum Africa Twin
    Last Post: 03-09-09, 03:15 PM
  3. Xenon Lights
    By btbloke in forum Mechanical Advice
    Last Post: 17-06-08, 01:38 AM
  4. Xenon Bulbs
    By Raven in forum Transalp
    Last Post: 16-01-08, 12:51 AM
