Results 1 to 10 of 13
Thread: fuel pump relay maybe?
    wild rover is offline Junior Member
    Jul 2010
    ilkley , yorkshire
    hi good day , sorting my new to me rdo3 , booked it in for mot ,took it for a spin then bad news fuel flowing out of overflow pipe to carbs when engine is running , i saw a post by RAYMO about fuel pump cut off relays could this be my problem aiso , the bike has been stood for seven years it needs love thanks John.
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: fuel pump relay maybe?
    That relay is designed only to cut off the the fuel pumps electrical supply and you mentioned the carbs are spewing with the engine running. High fuel pressure will cause fuel to overflow the carbs. What type of fuel pump are you running?
    Kjell Lindberg's Avatar
    Sweden
    Stod still for 7 years?
    Were carbs cleaned and emty before standstill?
    I suspect there could be "dirt" from old fuel inside the carbs.
    Open up the float bowl (4) and check and clean the valve (2).
    On your description it could be that the carb is overflowing caused by a leaky bowl camber valve (Or whatever this part is called in English...)
    The valve (2) should close when it's pressed uppwards by the float (3) wich in turn is moved by the fuel level inside the bowl (4).
    If the valve is not closet properly in the seat due to dirt between the needle and the seat, the carb will overflow with fuel.
    It could also be caused by a punctured float, since in that case the float will not follow the fuel level and put pressure on the valve, keeping it open and overflowing the carb.
    Also check all fuel lines for any holes due to detoriating, or it could be as simple as a missing fuel line clamp.
    I positive that it's not the fuel cut off relay, as that relay stops the fuel pump when the engine stops, and starts when the engine is running.
    Fuel pump (3) and fuel lines:
    Parts list and fiches RD03:
    http://www.xrv.org.uk/media/XRV650K.pdf
    //Kjell
    Jul 2010
    ilkley , yorkshire
    hi thanks for your response, i dont know for sure i think its a stock Honda one. I thought the relay might cut power to the pump when the carbs are full of fuel but because its naff its not stopping the flow, maybe the relay is not for this purpose?. maybe its the carbs that need attention, i just want to ride my bike not molatoff cocktail cheers john.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    Sticking fuel float in one or tuther of the carbs, caused by either sticking needle valve or crud.
    Strip & clean the carbs, measuring float level to ensure thats correct, re-assemble & ride
    Steve T
    PS - disclaimer - never, ever have I touched a RD03, so I could be talking total pants
    CaBRita's Avatar
    CaBRita is offline Member
    Oct 2009
    Lisboa, Portugal
    Hi, might be a novice question, but where can i find "Parts list and fiches" for RD07A, just like the ones shown above for the RD03?
    It looks to be a very interesting document
    Regards,
    Luís
    Sweden
    Luís, here they are:
    Link to Fiches:
    Honda Africa Twin XRV750 Site
    //Kjell
    cajka is offline Junior Member
    Sep 2010
    macedonia
    hello to everyone i have problem with the fuel pump that problem begains when i bought the bike i drive with the old batery and when the batery life go to ends the things go boom many things wasnt in function like fuel pump lights regulator recitifer rpm meter . . . i replace the batery and regulator recitifer and fuel pump but i cant find the original fuel pump and i put a universal and the bike havent the power when you thortle on the gas it work wrong one moment speed will go up one moment cant burn the gas . . .do you think is the fuel pump ? i will be happy if i find a solution for that problem . . . regard
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Sounds like your universal pump is the wrong type with a different flow
    get a facet
    Facet Fuel Pump / Pompa Benzina Facet - Detailed item view - RUGGED ROADS - Honda BMW KTM Motorcycle Accessory
    Sep 2010
    macedonia
    thanks man i will try with that . . . i think all will go on a right way x) i own you
  1. XRV 650 Fuel Pump Cut Off Relay
    By evilhomer in forum Africa Twin
    Last Post: 05-07-10, 08:49 AM
  2. fuel pump relay
    Last Post: 06-03-10, 11:33 PM
  3. Fuel pump cut off relay
    By tatoo in forum Africa Twin
    Last Post: 12-02-09, 08:52 AM
  4. Replies: 3
    Last Post: 12-05-08, 11:18 PM
  5. fuel pump relay switch
    By barbarabainbridge in forum Africa Twin
    Last Post: 20-06-07, 12:40 PM
