Results 1 to 4 of 4
Thread: Q: Rear shock RD07A specifications?
    Kjell Lindberg's Avatar
    Sweden
    Can someone tell me the lengt of the shock between the mounting holes (c/c)?
    Also what diameter are the holes?
    Spring rate, anyone knows?
    Thanks! /Kjell
    desertjoe's Avatar
    desertjoe is offline Senior Member
    Apr 2010
    Namibia, Swakopmund
    Re: Q: Rear shock RD07A specifications?
    with or without the spring? mine with spring still attached and on max setting is 38.5 cm. the bolts are 10mm each
    Sweden
    Quote Originally Posted by desertjoe View Post
    Thanks Desert-Joe!
    I'm investigating if there are other bikes that have shocks that could be used for the @
    I have to start with the mechanical dimensions, and then move on to spring rates and damping caracteristics.
    //Kjell
    raymo's Avatar
    aberdeenshire Scotland
    Quote Originally Posted by Kjell Lindberg View Post
    Thanks Desert-Joe!
    //Kjell
    the RD07 shock is about 5cm longer than the RD03/4
    XRV 650R RD03 1989
    The Longest Day Rider 6
  1. will an RD04 rear shock fit an RD07a?
    By tomodan in forum Africa Twin
    Last Post: 28-06-10, 07:48 PM
  2. SLR 650 Rear Shock
    By captainmish in forum Dominator / FMX
    Last Post: 06-07-09, 09:27 PM
  3. Wanted: Ohlin's Rear Shock RD07A
    By Paul-S in forum For Sale / Wanted
    Last Post: 30-06-09, 09:30 PM
  4. Removing shock spring on RD03 rear shock
    By holla in forum Africa Twin
    Last Post: 09-05-09, 05:41 PM
  5. Rear Shock ?
    By GIDEON in forum Africa Twin
    Last Post: 28-01-08, 06:47 AM
