Results 1 to 6 of 6
Thread: fuel pump orientation - quick question
    sjk6000 is offline sjk1000
    Sep 2006
    uk
    Hi all
    Just fitting a standard fuel pump I picked up from wemoto and noticed that the orientation between front and back is different to the original. I've baffled myself now trying to figure it out. Which is the inlet on the pump? Is it the open one or the closed? My guess would be the open but I thought I'd run it past you guys to be sure.
    Thanks, Steve
    lootch67's Avatar
    South Ockendon, Essex
    Re: fuel pump orientation - quick question
    Not sure if this helps but AFAIK the side with the electrical connections faces forward.
    Sep 2006
    uk
    Thanks for the quick reply Lootch. I think I may have confused things with my thread title. Looking at the inlet and outlet on the pump, one is open and one appears to be closed. Which of these is the inlet that the hose from the tank attaches to? Is it the open one or the closed?
    Cheers, Steve
    you are not mad, the outlets swapped sides after Honda updated the pump for a problem it doesn't have, never has had and never did exist (well according to a nice letter they sent me in 2001).
    If you do a search it's been mentioned on here before which way round it is on the two types of original equipment pumps.
    lootch67's Avatar
    Don't know, but there's only one pipe each side so if the orientation is right it should work. If there's still some fuel in the carbs you could hook the pump up, start the engine and feel which side is blowing and which side is sucking to confirm.
    Sep 2006
    uk
    Great, thanks guys. I had a browse of the forum before I posted but mostly got facet pump threads. Will dig it out.
    Cheers, Steve
  1. Fuel pump question
    By marty3000 in forum Yamaha
    Last Post: 18-08-09, 07:56 PM
  2. SD01 fuel pump similar to AT pump?
    By marc lenssen in forum Varadero
    Last Post: 22-05-09, 07:42 PM
  3. Fuel gauge/fuel range/fuel pump
    Last Post: 14-03-09, 09:27 AM
  4. rd04 Fuel pump question
    By dirtyden in forum Africa Twin
    Last Post: 08-04-08, 08:49 PM
  5. Quick check to see if fuel pump is broken?
    Last Post: 17-09-04, 05:30 PM
