Results 1 to 10 of 17
Thread: main stand spring...help.
    Betterl8thanever's Avatar
    Betterl8thanever is offline Senior Member
    Apr 2010
    Henley Upon Thames
    Hi guys, fitted new main stand, but can not get the spring to attach to the lug. ive tried levering it with a screwdriver, through the top tube on the stand, i get it nearly there but cant get it off driver and onto lug. Wrecked two drivers now. Tried with pliers but spring is too strong and lose grip, stood bike on stand but that dont help. Is their a special tool to attach spring or do i need to get down the gym?
    Any advice greatly appreciated, Cheers Li.
    jasonbc's Avatar
    Camborne, Cornwall
    Re: main stand spring...help.
    Quote Originally Posted by Betterl8thanever View Post
    Make a spring puller, a peice of wire like a thick welding / brazing rod bend one end at 90 degrees so you can pull it and at the other end bend a tight u on it, then you can hook the spring and then pull it onto the stand
    GASGAS TXT250 PRO 2006
    raymo's Avatar
    aberdeenshire Scotland
    ohh did this on the alp..
    even tried leaving the pivot pin out and attaching the springs then trying to man handle the stand to line up and put the pin back in.. not enough hands .. eventually went back to trying to lever the spring back on.. had finaly given in ... give it on last go and made it..
    lost some skin in the process.. dont envy you with that one ,, brut force I am afaid.. and they are so tight to the down pipes too
    XRV 650R RD03 1989
    The Longest Day Rider 6
    Windmill John's Avatar
    Oct 2008
    Don't know how different it is on the AT, but I put my springs on first and then levered the stand into place.
    At least there is more to get hold of with the stand.
    I popped the shaft partly through and putting my body into the wierdest shape, tapped the end of the shaft through when I levered the stand.
    Get someone else to tap it through; much easier
    Honda Transalp XL650
    BMW R65
    First Honda CB200 in 1978
    Biggest Honda CB750F2 in 1981
    Lots in between
    Have you not heard of the 2p coin trick? Bend the spring so the joints open and place 2p coins in each gap as you work your way along it, lengthening the spring temporarily. Or was it 1p coins?
    Oct 2008
    I like the sound of that 2p trick
    BMW R65
    Lots in between
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Quote Originally Posted by Windmill John View Post
    That's what I did on my @, but got the missus to push the pivot through.
    Sent from my GT-I5700 using Tapatalk
    Apr 2010
    Henley Upon Thames
    Guys ,
    brilliant advice, will try the spring puller method as i have been nearly there on a couple of attempts.
    The 2p coin trick is clever but there ars two springs one inside the other so may well be tricky. but if puller fails i will try this in combination with puller. Dont want to dismantle again as its caked in grease and the split pin is bent through levering against it with screw driver!
    Hopefully just as im about to quit i will get it...Thats Life.
    Thanks for your help. Li.
    raymo's Avatar
    Guys ,
    yup tried all that .. the pin in last is workable but you need a third hand.. as i managed to do it but feck....me.... totally b0lloxed afterwards.. ohh and count your fingers
    XRV 650R RD03 1989
    Whealie's Avatar
    Whealie is online now Wing Commander
    Lewisham, SE London
    We've all been there.
    centre stand spring
  1. T/A 650 main stand
    By buzz in forum Transalp
    Last Post: 26-05-10, 08:00 PM
  2. Wanted Main/Center stand
    By alO49 in forum Transalp
    Last Post: 12-11-08, 09:42 PM
  3. Side or Main stand ?
    By peelerfart in forum Mechanical Advice
    Last Post: 31-07-08, 09:39 PM
  4. Wemoto Main Stand
    By BuckarooBanzai in forum Transalp
    Last Post: 07-06-07, 05:04 PM
  5. Main Stand Question....
    By Ratrap in forum Africa Twin
    Last Post: 08-04-07, 08:54 PM
