Results 1 to 1 of 1
Thread: Rear shock RD03 - RD07A
    Kjell Lindberg's Avatar
    Kjell Lindberg is online now Senior Member
    Sweden
    Some information from different sources on the webb:
    Rear shock RD03 and RD04:
    Free length = 240 mm
    Spring 9.5 turns
    Diameter damping rod: 14 mm
    Internal diameter: 57 mm
    Diameter: 85 mm
    Weight 2200 gr
    SPRING RATE = 100kg/cm
    0 kg (free length)> 240 mm (0 mm compression)
    50 kg> 235 mm (5 mm compression)
    103.9 kg> 229 mm (11 mm compression)
    150 kg> 224 mm (compression 16mm)
    Rear shock RD07 and RD07A
    Free length = 245.5 mm
    Spring: 9.5 turns
    Diameter damping rod: 12 mm
    Diameter: 81 mm
    weight 1800 gr
    SPRING RATE = 70kg/cm
    0 kg (free length)> 245.5 mm (0 mm compression)
    113.5 kg> 230 mm (15.5 mm compression)
    147.2 kg> 225 mm (20.5 mm compression)
    152 kg> 224 mm (compression 21.5 mm)
    Race sag
    The rear suspension on the Africa Twin has a length of movement of 70 mm.
    However these 70 mm becomes 210 mm amplified through the Pro-Link that has a 1:3 rate.
    Rule of thumb states that Race sag usually should be 1/3 of the maximum suspension travel:
    http://www.4strokes.com/tech/racesag.asp
    1/3 of 210 mm is 63 mm.
    //Kjell
  1. Q: Rear shock RD07A specifications?
    By Kjell Lindberg in forum Africa Twin
    Last Post: 23-08-10, 01:43 PM
  2. will an RD04 rear shock fit an RD07a?
    By tomodan in forum Africa Twin
    Last Post: 28-06-10, 07:48 PM
  3. Wanted: Ohlin's Rear Shock RD07A
    By Paul-S in forum For Sale / Wanted
    Last Post: 30-06-09, 09:30 PM
  4. Removing shock spring on RD03 rear shock
    By holla in forum Africa Twin
    Last Post: 09-05-09, 05:41 PM
  5. Replacement RD03 rear shock
    Last Post: 23-04-09, 08:02 PM
