Results 1 to 4 of 4
Thread: AT off the road for a bit - subframe TLC????
    futter's Avatar
    Jul 2005
    Suffolk
    Like many At's my subframe is a bit rough. Solid but rough. Got to come off the road for a bit (finances) so had a look.
    After some thought, I got the drill and wire bruch out and cleaned up a small section, wiped it down and then painted with plain white gloss. Good old fashioned gloss for metal/external. Still drying but looks ok. It is stays looking good am gonna strip whole subframe down and repeat (prob using a decent metal primer)
    Not gonna be profesional, or last more than a few years to be honest but if it does - who dares wins!
    futter's Avatar
    Jul 2005
    Suffolk
    Re: AT off the road for a bit - subframe TLC????
    Well - tried a small area but due to how it took, am gonna clean it off and use smoothright (white) as it needs to primer/undercoat and while you can brush off loads of crud, it will go onto rust. That will take place over the next week - will take pics.
    desertjoe's Avatar
    desertjoe is offline Senior Member
    Apr 2010
    Namibia, Swakopmund
    are you gonna strip out the whole frame? if so you can just as well go the full monty!
    futter's Avatar
    Jul 2005
    Suffolk
    No - this is a quick fix for this year - only just put a new engine in - don't fancy that again! But, looking at how well it has taken and problems not with standing I will do the whole frame next year.
    In the end I use my dril with some wire brushes - worked a treat - the Hammerite doesn't need primer/undercoat and goes straight onto bare metal and even rust so long as you have removed the loose toot.
  1. Replies: 4
    Last Post: 07-06-10, 09:32 PM
  2. AfricaTwin RD04 front subframe
    By anton88 in forum For Sale / Wanted
    Last Post: 31-07-08, 09:38 PM
  3. XR250r off-road to road conversion
    By Nogrog in forum XR
    Last Post: 06-04-08, 03:33 PM
  4. XR400 Subframe strengthening
    By Warthog in forum XR
    Last Post: 26-12-07, 08:43 PM
  5. Off road on the @ with road tyres!
    By McFly in forum Ride Reports and Pictures
    Last Post: 02-11-07, 10:20 PM
