Results 11 to 20 of 21
Thread: Carb synchroniser
    Windmill John's Avatar
    Oct 2008
    Re: Carb synchroniser
    Goes to show; pros and cons:
    Mercury into engine!
    Remove the air bubbles!
    Not a problem with gauges, but I would hate to drop gauges; even from a few inches.
    Honda Transalp XL650
    BMW R65
    First Honda CB200 in 1978
    Biggest Honda CB750F2 in 1981
    Lots in between
    I bought these from M&P.
    Used them on a Transalp and Whealie has borrowed them for his @.
  4. #13
    Boris's Avatar
    Oct 2006
    Edinburgh, Scotland
    Quote Originally Posted by Windmill John View Post
    The big pro with mercury is calibration. Unless something really odd happens to air pressure or gravity then they will always be accurate.
    I'm on the Safe House List
  5. #14
    Lutin's Avatar
    Galway
    Got my set from Wemoto. These come with damping valves to reduce the needle oscillation. They work, what more can I say?
  6. #15
    psi's Avatar
    psi
    psi is offline a tool
    Jun 2009
    Tampere, Finland
    I've the carbtune pro. They have metal rods in the tubes. You must use restricted rubber tube inserts to dampen airflow, otherwise the reading will bounce just like with dials (all that's needed comes in the package). I've used it a couple of times, very easy and fast thing to check (carbs have stayed within 2mmHg so no adjusting for me).
    Delivery was some 4 days to Finland.
  7. #16
    trophydave's Avatar
    trophydave is offline Senior Member
    Feb 2007
    Nottingham
    I have a set of the dial gauges but I always borrow my mates Carbtune,personally I think that it's better
    Rust never sleeps
  8. #17
    myfirstxrv's Avatar
    myfirstxrv is offline Member
    Bournemouth, England
    I've got the Hein Gericke dials - Easy to use and come with neccesary hoses and brass adaptors. The damping is not particularly advanced but does the job just fine
    RD07 Black, new ratios, facet fuel pump, Mitas E07 rubber, homemade top box, centre stand, heated grips, tall screen.
    Speed Triple 955, green
    R1 streetfighter, proper scary
  9. #18
    XR Mad's Avatar
    XR Mad is offline Senior Member
    South wales
    Just ordered a morgan carbtune from M & P and will report how good or bad it is when i use it. I was going to make my own i can buy accurate glycerine filled gauges for about £17 each i may still go down this route if the morgan ones are sh1te.
  10. #19
    RodYork's Avatar
    RodYork is offline Senior Member
    Jul 2009
    York
    I did a video on balancing using carbtune on a Fazer. They are simple to use on an @ & are great....you will note I now have a suntan
  11. #20
    sixtring74 is offline Senior Member
    Dec 2005
    Peterborough
    Call me old fashioned... If I’ve got time I’d use a gauge but a bit of pipe and my ear seems to have done pretty good job with all the carbs I’ve balanced. If they sound the same they’re sucking the same. I know this won’t be as accurate as a gauge, but it’s worked for me so far. I’d always use a gauge on a highly strung sports engine but the good old 750 twin is a little more lenient.
    Am I gonna get nagged at now?
    XRV750 Africa Twin, Geared to tour. KTM 250 EXC ready to Race. Riden, filmed and Edit two Adventure Motorcycling documentaries -Aim For The Horizon and Adventure Motorcycle Morocco - Would love to tour the World... Watch this space.
  1. Carb's
    By VENNIC in forum Africa Twin
    Last Post: 24-06-10, 06:23 PM
  2. SLR CARB
    By imingors in forum Dominator / FMX
    Last Post: 10-12-08, 08:05 PM
  3. Help with carb please!
    By brko in forum Africa Twin
    Last Post: 24-06-08, 08:33 PM
  4. AT carb question
    By trophydave in forum Africa Twin
    Last Post: 07-05-08, 08:20 PM
  5. carb set up
    By Simmo in forum Africa Twin
    Last Post: 17-07-06, 05:44 PM
