Results 1 to 3 of 3
Thread: RD07 regulator ?
    Daltonegra is offline Junior Member
    Jul 2009
    Slovenia
    RD07 regulator ?
    Yellow all!
    One technical question.
    Today I've fitted digital voltage meter display instrument / gadget to my '96 AT just to be shure when my regulator will start showing signs of weakness.
    Started up... everything is fine. Voltage shows from 12,3 to 13,5 approx. Then I went for a spin around town and I've noticed that when I make more speed / revs the voltage is descending to 12.0 then 11.8, 11.5, 11.0 even 10 or 9,8 volts wich is seriously low. Then when i pulled over, put in neutral-motor running. The voltage came slowly back to 12,5. Pulled off and same thing... voltage came down.
    I/ve read the forum and most common problem is too much voltage. Is this also a regulator problem? What are the consequences?
    Thnx for advice/answers,
    jURE, Slovenia.
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: RD07 regulator ?
    Put a digital multimeter across the battery posts at various revs just for comparison. If you have had no charging issues or dead battery in the past then it may just be your new voltmeter indication or connection.
    raymo's Avatar
    aberdeenshire Scotland
    I have had a a few reg rec issues this year.. the new to me At had a new battery fitted and the reg was only giving out 12+ volts..should be 13.6+
    the reg can give low volts.
    fitted an R6/R1 regulator of the Ebay, it was an SCR type not the newer FET , but volts are now 13.6 the volts will rise from tickover but should stabilise above 2-3000 rpm.
    Measure the voltabe at the battery...
    The XLV reg fried ( 18+ volts this time so I fitted the AT one to it and got another R1/R6 regulator of Ebay.. this one is from a pre 2006 R1 and is an FET 50A unit the size of a brick ( at work so cant recall, but its off a R1 5VY ft 011AA from memory. will take 100v AC 3 phase and rated at 50@ 14.5V 725 watts.. the AT gives out 350w max so should run cool )
    this would not fit the XLV.. no room as I say it's huge.. its the same foot print as the other regs but tall .. the fins make it 50-60mm high....
    fitted to the AT 14.5v at 1000rpm !! does not even get warm!! it would not fit under the seat so it,s mounted on the right where the RD04 water expansion bottle is.. but as mine is an RD03 ( RD04 motor.. long story) there is room there..
    cheched at the battery and it gives 14.5 votls no variation from tickover right through the rev range.. brilliant..
    I have a garmin V GPS and if you hold the enter key down as you power it on the unit comes online with a diagnostic page. This shows what supply voltage the unit is getting.. 5-6v on internal battery.. 12.5 ish when the ignition is on and 14.5 when the engine is running .. however the unit is tied into a switched feed in the headlight cowl.. switch the lights on and it drops to 12.5 !!! checked the battery 14.5.. so volts drop across the wiring to the highlamp, ( these are the high current draw 2x 55w pulls about 8-10 amps, 0.2 ohm resistance of the wiring and associated connectors gives 2 volts drop ( this is 20watts going as heat .. winter job will bit to fit relays and a big fat cable ( 30amp fused ) up to the headlight to overcome this..
    sorry for the detail, but bottom line is that, as said, you need to measure the voltage at the battery if the reg is giving out less than 13.5 volts above 2000rpm.. its stuffed, but not in a bad was .. my XLV reg was giving out 18+ at 3000rpm .. more above that, so kept it down while I limped to the bike shop.. it took out the battery .. and the stator windings
    so a low volts reg .... is it bowing out gracefully
    get an FT 0012 or if you have room the FT 0011
    Firestorm / SuperHawk (VTR1000F) Regulator Rectifier Modification
    sv650_vrr_upgrade
    XRV 650R RD03 1989
    The Longest Day Rider 6
  1. Regulator
    By Lee Halsall in forum Africa Twin
    Last Post: 13-07-09, 06:34 PM
  2. regulator/rectifier
    By LEOPARD in forum Africa Twin
    Last Post: 04-08-08, 07:00 PM
  3. Regulator
    Last Post: 26-11-07, 01:23 PM
  4. What does a regulator do !!!!
    By Phoenix in forum Africa Twin
    Last Post: 27-10-04, 05:09 PM
  5. Regulator - differences between RD04 & RD07???
    Last Post: 30-09-04, 01:57 PM
