Results 1 to 9 of 9
Thread: RD07A '97- What spares for a West Africa trip
    CaBRita's Avatar
    CaBRita is offline Member
    Oct 2009
    Lisboa, Portugal
    Hello,
    I’m beginning preparation for my trip through West Africa. It will be a 5’500 km tour, lasting 2 weeks. Expected terrain is 90% tarmac, 10% gravel.
    The bike that I’ll take is a ’97 Honda Africa Twin that I bought 6 months ago and it now has 30’000km on the clocks.
    Beyond the normal service these are the extra tasks that I intend to perform. And this is where your feedback and experience is needed:
    • Clutch and throttle cable - will pre-install alongside the existing ones. If the originals break it’s an easy fix
    • Regulator - I plan to take a spare regulator. AT regulators are prone to fail. Anyway I’ve installed recently a voltmeter in order to check the regulator’s health and predict problems in an early stage
    • Fuel pump – the existing pump is still the original one (13 years…). Still hesitating to take a spare OEM or install the acclaimed Facet
    • Clutch and brake levers – will take a pair of levers. I have handle bar protection but who knows, I don’t want to get stranded in the middle of Africa because of a cheap lever
    • Wheel bearings – will replace before leaving. AT rear wheel bearings are prone to fail
    Feedback is welcome! On the points mentioned and some others that you think of.
    Best Regards,
    Luís CaBRita
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: RD07A '97- What spares for a West Africa trip
    You seem to have it pretty much covered, new set of tyres and mayby chain set and enjoy your trip
    the rest would be tools for the unexpected
    The facet can be had from Rugged Roads give Annette a PM or mail them
    Ruggedroads.co.uk
    GSPD750's Avatar
    Calgary, Alberta Canada
    Your looking good. However.......i would replace that fuel pump now...... or bring a spare. As mentioned already the Facet is the way to go. Have a great trip!
    CaBRita's Avatar
    Oct 2009
    Lisboa, Portugal
    Thank you for the feedback!
    I'll depart with the standard fuel pump and take the Facet as a spare (together with your clear mounting instructions ) - Facet fuel pump installation...long
    Best Regards,
    Luís CaBRita
    lootch67's Avatar
    South Ockendon, Essex
    If you have proper hand guards I'd rather take a spare gear and break lever if space is an issue. Other items I'd consider:
    1.) A selection of spare nuts and bolts
    2.) Pratley steel
    3.) Spare headlamp if you're expecting to do some night riding.
    4.) Spare fuses and some electrical wire + insulation tape. I have a small multimeter which I always carry with me. Some spade connectors?
    5.) Everything needed to change a tyre by the side of the road.
    6.) Gaffer tape and cable ties.
    7.) Tools. Make sure you have the AT spark plug tool and a screw driver that's long enough to fit in the fuel tap so you can unto that to take the tank off. Both of these should be in the standard AT tool kit.
    8.) Spare spark plug?
    Now I've got a headache. Good luck with the trip!
  7. The Following User Says Thank You to lootch67 For This Useful Post:
    CaBRita (12-05-11)
  8. #6
    Zenarchy's Avatar
    North East UK
    Self amalgamating tape - like this stuff:
    Ultratape SOS Repair Bonding Tape Silicone Pipe Rubber on eBay (end time 15-Sep-10 18:59:38 BST)
    Might be handy, as it can be used as an insulating tape for electrics (so no need to take regular insulating tape too), but is also waterproof so can repair leaky connections or hoses (amongst other things). The type like that one above with a thicker material backing tape seems to be better than the ones with the thin plastic backing (though there are lots of other brands available too).
    Might be overkill, but I carry a tiny cheap gas soldering iron too (came in handy last year). You can pick these up very cheaply from ebay and while they're a bit rubbish compared to a decent gas iron, they're very cheap and small so light and take up little space, and can be used as a little gas torch with the solder tip removed.You need to be careful about the tips coming loose and falling off some of the cheaper ones when they heat up though, and I'm not sure if you'd have an issue crossing borders carrying them if anyone found them.
  9. #7
    GSPD750's Avatar
    Quote Originally Posted by lootch67 View Post
    2.) Pratley steel
    Absolutely. Minimum 3 tire irons and a patch kit...and a mini air compressor
    as an added bonus providing you have the room.
  10. #8
    Simonz's Avatar
    Simonz is offline Junior Member
    May 2009
    London
    Hi there, I just returned from riding my RD07a from London to Cape Town via the West Coast of Africa. 23,000km and my AT didn't miss a beat. Sure, a bit heavy and a little tricky to ride in deep sand but what a machine!!!
    Spare I took
    Regulator
    Inner tubes
    Spark Plugs (not sure you will need a full set for 5,500km - maybe a spare?)
    Fuses
    Tyres (TKC80s) - rode on my road tyres to W Sahara and changed them there - again you prob won't need spares for 5,500km as long as there is plenty left at the time you leave)
    CDI - didn't use
    Clutch lever - did use
    Bit of top up oil
    Before Leaving
    Chain & Sprockets
    Change fuel pump for facet
    Crash bars - SW motech are the best IMHO
    New pads and brake fluid
    New plugs & oil change
    Headlamp guards - cheap perspex ones worked fine
    Do some practice tyre changes - easy once you get the hang of it
    Puntures - I got quite a few
    2 x levers, valve tool, patches (lots) glue, talc, soap, mini compressor, backup manual pump
    - Take the plastic fork guard fairings off aswell - easier and quicker access to front tyre
    Useful kit
    Duct tape, cable ties & jubilee clips (assorted sizes), super glue
    Tools - Honda kit should do you
    Bit of sturdy wire
    Could have done with
    spare rear brake pads - I lost one in Gabon
    Tips
    Pack light - the AT is heavy enough. eg, change the fuel pump for a facet before leaving instead of taking a spare
    Make up some fische - printed details in french for you and your bike - v useful in Morocco, W Sahara and Mauritania
    Don't pay bribes
    If you are going there - enjoy Mali - amazing country
    Moto cross boots - great protection - saved me a few times
    Wild camp as much as possible
    Take water bag (Ortlieb do a 5L or 10L bag) - fill up from wells or pumps in villages (Mali) or at servos - water was fine
    Enjoy!!
  11. The Following User Says Thank You to Simonz For This Useful Post:
    CaBRita (12-05-11)
  12. #9
    myfirstxrv's Avatar
    myfirstxrv is offline Member
    Bournemouth, England
    Before a very similar trip I "slimed" my tyres unlike my buddy. I never needed to repair a puncture (on my bike!!) - was it luck, does it work, I don't know but he did get a couple.
    Watch out for the speed cameras around Casablanca.
    Can't recommend doing a fiche too much - saves ages at borders and checkpoints. I'd reccomend printing 10 or 15 off.
    I've got some notes from 2 1/2 years ago if you have any specific questions PM me
    RD07 Black, new ratios, facet fuel pump, Mitas E07 rubber, homemade top box, centre stand, heated grips, tall screen.
    Speed Triple 955, green
    R1 streetfighter, proper scary
  1. trip to west africa
    By oldtimer in forum Ride Reports and Pictures
    Last Post: 12-08-09, 10:17 AM
  2. For Sale: Africa Twin spares
    By boboneleg in forum For Sale / Wanted
    Last Post: 09-12-08, 02:25 PM
  3. Wanted: RD07a Speedo required as digital trip not working
    By kitped in forum For Sale / Wanted
    Last Post: 01-10-08, 01:25 PM
  4. Africa Twin spares for sale
    By sting-stiz in forum For Sale / Wanted
    Last Post: 17-04-08, 08:01 AM
  5. maverick just for you. key west trip
    By fat bloke in forum Chatter
    Last Post: 24-11-06, 06:13 PM
