Results 1 to 4 of 4
Thread: Tick Over??
    landyandy is offline Senior Member
    Kent & London - whereever, really
    Tick Over??
    Ok - should be an easy one, this ... couldn't find the data in my manual, so thought I'd get a consensus ....
    What revs do you folks set your tick over to? Or is it just a case of finding the point at which the engine is smooth?
    Ta.
    When mine is running properly it ticks over at exactly 1000rpm. On a hot day with the engine fully warmed that will increase to about 1100
    SteveLee Guest
    If I remember correctly the Haynes manual recommends 1200rpm, which is what I set mine to. Unlike Abingdon Motorcycles - when it came back from it's 12k service it was ticking over at 1800!
    Steve
    Thanks. Got mine sitting at about 1500 rpm at the moment, but I'll see if it's happier a little lower down the rev range.
  1. Tick-over adjuster RD04
    Last Post: 26-12-06, 04:02 PM
  2. tick-over - stalling
    Last Post: 03-04-06, 09:51 PM
  3. rd03 tick-over
    By biker6991 in forum Africa Twin
    Last Post: 08-04-05, 10:47 PM
