Replacing valve stem seals
Results 1 to 3 of 3
Thread: Replacing valve stem seals
    hesekiel is offline Junior Member
    Aug 2011
    Finland
    Hi,
    my RD04 has begun to consume oil more than 1 liter per 1000kms at 120000 kilometers. It runs normally and idles ok. I suspect valve stem seals are about to expire. Is it possible to replace seals without removing cylinder heads (and engine)? I have an air pressure tool that can keep cylinders pressurised during operation. I would hate to do anything extra and unnecessary to good engine...
    Cheers,
    Hesekiel
    Jakey is offline Senior Member
    Nov 2011
    Bedfordshire
    Pretty sure you need to remove head, to remove valves and then change seals
    Easy enough job with a manual at hand
    jasonbc's Avatar
    Camborne, Cornwall
    Re: Replacing valve stem seals
    Best check your valves guides for wear aswell if your taking your heads off, pointless putting new stem seals on and then finding your guides are knackered would be bit of a pointless exercise
    GASGAS EC300 2006
  1. xr 250 valve stem seals
    By malwelder in forum XR
    Last Post: 16-12-09, 05:53 PM
  2. xr 250 valve stem replacement Help
    By CHEWEYCHEWT in forum XR
    Last Post: 09-11-09, 11:29 AM
  3. xr 250 valve stem replacement Help
    By CHEWEYCHEWT in forum XR Technical Specs
  4. Valve stem seals, replacement, how easy?
    By richie in forum Dominator / FMX
    Last Post: 01-11-09, 08:06 PM
  5. Valve stem seals
    Last Post: 05-06-05, 10:37 AM
