Results 1 to 7 of 7
Thread: RD04/07 Panniers Interchangeable?
    miggy is offline Senior Member
    Jul 2004
    London
    Probably been asked before but I can't find any info' about this.
    Are RD07 panniers interchangeable with the RD04?
    Where can I get Panniers for an RD04? I can get RD07 panniers no probs' but can't find anything for the RD04.
    Advice appreciated, thanks.
    iswoolley's Avatar
    Jun 2004
    Telford, Shropshire
    Miggy, it ain't the panniers that are the problem it's the frame that carries them. For example the Touratech site only lists a frame for the RD07, not the RD04. The Givi website lists the Wingrack system for Africa Twins starting in '93, which I guess is the first RD07s.
    You might have to get hold of some Zega boxes from Touratech and then get someone like Ernie at Overland Solutions to custom make you a frame.
    Iain
    I had Givi panniers on my RD04 in 1997 so there used to be a fitting kit for the side frames. I remember one part bolted over the top of the rear rack. I'd try advertising for somebody's old fitting kit. It's only a few tubes and some bolts.
    Jul 2004
    London
    Cheers geezers.
    I was of course refering to the carriers being interchangable not the actual panniers which I know can fit more or less anything.
    Anyway thanks for the links and info' which seems to indicate that Givi at least have something. I'll check 'em out. As it happens I already have a Kappa topbox.
    (The gear-4bikers link doesn't seem to work?)
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Quote Originally Posted by miggy
    http://www.gear4bikers.co.uk/
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    Jul 2004
    London
    Cheers Dave.
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    2010 KTM 450 EXC-R
  1. Interchangeable plastics?
    By Taz in forum Varadero
    Last Post: 20-12-06, 10:48 PM
  2. RD03/RD04/RD07 Tank & plastics interchangeable?
    By jfitzsimons in forum Africa Twin
    Last Post: 18-02-06, 07:03 PM
  3. Interchangeable Parts
    Last Post: 04-10-05, 04:01 PM
  4. Soft panniers (e.g. Andy Strapz) V hard panniers
    By TallJohn in forum Africa Twin
    Last Post: 02-08-05, 02:19 AM
