Results 1 to 5 of 5
Thread: Anyone got a flywheel bolt removal tool?
    landyandy is offline Senior Member
    Kent & London - whereever, really
    Hi,
    I think I've worked out why my RD04-RD07 transplant isn't successful ... the flywheels have their contact points in different places (the RD04 has 2 opposed to each other, whereas the 07 has several) - hopefully this will explain the lack of ignition.
    Therefore, I need to remove the flywheel, but as usual, I can't begin to shift the bolt, despite putting the engine in gear and reversing it into a wall (yes, I know that it's a reverse thread).
    So, does anyone have a flywheel bolt removal tool that I could beg or borrow?
    Much appreciated.
    Thanks.
    RD03 Barbie's Avatar
    RD03 Barbie is offline Middle-aged Junior Member
    Tuscany
    Re: Anyone got a flywheel bolt removal tool?
    To remove the bolt I just wrapped a couple of turns round the flywheel with some webbing then tightened it up on the bit sticking out of the centerstand I used a ratchet as used to tie down boats to their trailer but I am sure any trucker has something similar. The flywheel came (flying) off with a sturdy puller and a couple of taps with a big hammer.
    Sometimes the rear axle is the correct thread to remove the flywheel. Worth a look, it's worked for me on 2 bikes so far.
    therebelmc is offline Junior Member
    Bournemouth
    As i'm in need of a removal tool the info i've found so far is its an M22 x 1.5P thread...not so easy to find. WWW.PITPOSSE.COM in the USA can help.
    GSPD750's Avatar
    Calgary, Alberta Canada
    Scroll down this link for info.
    Tip for engine removal / replacement and other tips
  1. Nice Alloy Bolt on bits fo AT ( and others)
    By magwa in forum Africa Twin
    Last Post: 09-10-06, 04:08 PM
  2. Zega mounting bolt
    Last Post: 30-05-06, 08:34 PM
  3. Replies: 1
    Last Post: 10-02-06, 09:17 PM
  4. Rounded off bolt head - help!
    By Gav in forum Africa Twin
    Last Post: 03-02-06, 01:05 PM
  5. Nut and Bolt chain adjusters anyone?
    By Mutley in forum Africa Twin
    Last Post: 08-01-06, 06:09 PM
